heater control valve for 16V engine
I suspect I need to replace the heater control valve on an 87 944S 16V, or I have some major vacuum issue that is not effecting the engine running. common symptom, always HOT. I have already checked the flappy control in the footwell.
but so far I cannot find it down under the intake where the WSM says it should be. the 16V has a very different intake and occupies a lot of the space where all the docs I have read say it should be. looked in WSM, read Clarks garage writeup, PET. anyone know where it is located? searched threads but cannot find. |
Next to the oil filter
83-944 show room -sold___New ride 93-968 with SC steering wheel-ROW signal ligths- Susp M030 mods lowered,Porsche VA springs- Adjustable struts - Bilstein inserts - Bilstein sport rear -LSD -riding on Cup 1 wheels 17x8 frt 17x9.5 rear road contact Falken 452/ 225-45 ZR Front 255-40 ZR Rear -- Motor Mods /chip /K&N / mod air boxe just love the handling & power
AFM #725
That looks even worse than the NA haha, suddenly I feel better
What are the symptoms again? I have an 87 S and the engine is running hot. New water pump and new thermostat. Replaced coolant and bled it for a long time to get out any air bubbles. Still goes hot. Hot when idling. Cools down when driving. But gets hot sometimes when driving as well. Haven't figured out exactly when it goes hot and not.
Could it be my HCV too? Quote:
Current: 87 944S Black/Black, 89 944 Turbo S ANDIAL White/Burgundy, 78 924 Black/Black, 17 Cayenne S, 03 Turbo X50 Aero instagram @mhariush http://stores.ebay.com/Techniker-Parts/ |
AFM #725
I would see if your fans are working.
Fans run, hear them when i turn the car off. Pretty sure they run when i idle too, but will try and double check that.
When exactly should they go on?
AFM #725
They go on at a set temperature designated by your thermo fan switch, it should match the thermostat. I am replacing mine because I had the same issue where idling the temperature would get too high because the fans weren't running. Driving it would be nice and cool. I still am not sure if I just had too high of a temperature switch or if it was faulty.
You can refer to Clark's Garage Home Page for trouble shooting your car overheating issues,once on site enter "Garage Shop Manual " then scroll down to "Cooling System" could very well be a thermostat or thermo fan switch issue.Btw when was your water pump last replace?
Got it. I'll probably get a new temp switch then. Getting the one that will kick in at thw lowest temp sounds good then . I'm in LA so gets pretty hot during the summer
Hi ernie
I'll look over that again. Have new pump and thernostat, as noted in a couple of posts up. Have about 5k miles on them. Thanks
AFM #725
Try to get the one that matches your thermostat. You don't want the fans running before the thermostat opens or your fans will be constantly running and worked to death
That makes sense. Thanks
on the head doing it on a 16V.
Sorry should have read your post more carefully.
No worries ernie, appreciate the help regardles
If you drive the car on the open road or highway without stopping for 5 or 10 miles, what does the temp gauge read?
It should read at or below the first mark (about 1/3) If it is above this you could have a coolant leak, bad thermostat, clogged radiator, air in the system, blocked radiator air flow, bad water pump impeller, and a few other things. It would not be caused by the fans or the heater valve (unless leaking), though. |
It doesn't go tht cold, usually stays around the mid mark. I'm thinking I didn't get the thermostat seated properly in the water pump when I installed it.
AFM #725
Yeah it's not the fans if you are that hot on open road driving. Even when my fans weren't working right I was still at the 1/3 mark on the highway
there are a million possibilitie, so
Is it overheating enough to cause coolant loss thru the overflow tube? if not maybe the temp gauge is not accurate, or the sender is not good, or the radiator is mildly clogged, or the tstat is bad... |
