rear hatch lock
Hello, I am in dispair, I have stripped down my 944 back to shell for repainting. After refurnishing 95% of the car, I have come to a dead end. I cannot figure out how the short RH (standing from behind on a RH drive car) cable and lock fits back into the rear compartment, I have tried every which way but loose, but I cannot get it. Does anyone know where I can get a picture or a drawing of the assembly in position, I have a Haymes manual which claims complete strip down and rebuild but it does not show the rear hatch at all. It is the length that goes from the electric motor to the central key, but I cannot figure out the fixing at the key end. Any help greatly appreciated.
They are rubbish,I removed mine and the key always works unlike the motor system.
1985 944 2.7 motor,1989 VW Corrado 16v,57 project plastic speedster t4 power,1992 mk3 Golf,2005 a4 b7 qt avant 3.0 tdi,1987 mk2 Golf GTI,1973 914,2.2t to go in. Past cars, 17 aircooled VW's and lots of BMW's KP 13/3/1959-21/11/2014 RIP my best friend. |
AFM #725
Lol I have no idea how to get that electric one to work properly...
Watchdog Armory Racing AFM #725 Thanks to my 2017 Sponsors: JPH Suspension | AXO | Armour Bodies | BELL Helmets | Braven | EVLUTION Nutrition | Forcefield Armor | FunTrackDayz | Galfer | Motion Pro | MOTUL | Matrix Racing Concepts | ODI Grips | OGIO | Shorai Inc. | SPEEDMOB | Vortex | Woodcraft | Wicked Audio http://www.gawerracing.com |
Banned
Even if the little motor is good and works the hatch release button only actually opens the hatch of you have good strong hatch pistons. If those are strong enough to lift the hatch, theyll eventually separate the glass though.
Frankly my dear....
Hi there, if you do a search in the forum you should come across some useful info and pictures, etc.
Try looking for these threads:
Porsche - accept no substitute Blue 1999 Boxster - Brief encounter! Black 1988 944S - Ongoing project Black 1987 944S - Gone but not forgotten Metallic Black 1980 924 - Those were the days.... Red 1979 924 - Hmm Minerva blue 1979 924 - Where it all began! |
Frankly my dear....
The way I see it is, the glass is bonded to the frame, the pistons act on the frame, they do not exert any independant force on the glass itself. When the hatch is closed, the pistons are pushing in a horizontal axis. Now this might cause a degree of twisting at the piston mount, but looking at just how beefy the metalwork is, I kinda doubt it. When the hatch is released, the entire force is slowly transferred to the frame (and glass) in an arc aiming for vertical. Nothing is acting on the glass directly, it is being lifted via the frame. To help a separation, surely some external force needs to act on the glass? However, fatigue due to road vibration, thermal cycling, slamming the hatch shut, and UV breakdown will all cause the bond to fail, let alone the fact that it is getting old. These gradually-operating causes are probably more likely to contribute to any separation, not the pistons themselves. I may have gotten this all wrong though...?? Just as an aside, I have never actually come across a case of this happening over here in the UK. That doesnt mean it doesnt occur, but I have never seen it and I have looked at a lot of hatches in my time! Perhaps the more extreme environmental issues (heat and cold) are more to blame?
yarfk
A few pictures of my 87 hatch latch
Good Luck Keith ![]() ![]()
------Keith------kfray------yarfk------- 87 944 NA stock 116k 06 Honda Ridgeline 83k 10 Vibe 2.4 AWD (Wife's) Retired My week consist of Saturdays and Sundays
rear lock mechaniism
Thank you all so much for your replies, this forum is brilliant for novices like me, It is all working and so initially I would like to keep it original, Thanks again
Banned
The pistons continue to push on the frame 24/7 just because the hatch is closed does not mean they still don't have that "spring force" of the gas pistons pushing rearward on the frame. |
Frankly my dear....
I fully understand that the force remains pushing on the frame when the hatch is closed, however once closed, the hatch pins come into the equation as a pretty good stop. It's all very interesting..
Banned
I mean you don't have to believe me, but simply put that the biggest cause of separation is the hatch pistons. I'm not saying that is the only reason and I'm sure other stuff like thirty years of age comes to play like you said. Its clear that those who have replaced the hatch pistons and then had separation shortly after have reason to believe it was the pistons that were the final straw.
Frankly my dear....
Went and did some digging back in the forum, seems that this has been one of those recurring topics over time, many people have entered the debate with ideas and opinions and experiences..saw some photos too. It seems the concensus of all that is:
Poor design (but it has lasted 20+ yrs), frame material too soft, bonding getting old and cracking due to UV, heat, vibration, etc. as well as strut pressure. I think I will bow out of this one until it happens to me...but I sure hope it doesnt!
Banned
Oh it will, its going to happen to every single 944 hatch given enough time, there's nothing you can do but wait sadly. And I'm serious when I say sadly, because I never found a reliable safe or cheap way to fix it once it started.
Frankly my dear....
Hi fwayfarer .. didnt see your reply until after I posted mine! Yep, agree with what you say there.
All the best..
