Crippler's Avatar
Question Another Timing question
Okay so if I align the TDC marks on the flywheel and then align the marks on the cam tower before installing the cam tower. Will this put the engine in the right location for the timing belt to be installed?
1984 - Porsche 944
1994 Grand Cherokee
6inch Lift, 33" TSL'S
Old 07-12-2002, 04:38 PM
Scott R's Avatar
Maybe, but I would use the small view port window located below the reference sensor connections. Move the engine around unit you see a "0T" in the window. Then double check your work making sure the #1 piston is all the way at the top of its compression stroke.
2021 Model Y
2005 Cayenne Turbo
2012 Panamera 4S
1980 911 SC
1999 996 Cab
Old 07-12-2002, 05:19 PM
88_944's Avatar
Yes right on the money! Just check again when the cam tower is bolted on that the cam and the TDC marks are on target.
My Black 944
My Gaming Forums. Xbox360gen.com
Old 07-12-2002, 05:54 PM
Crippler's Avatar
Thanks, that was what I wanted to hear. the body will be back from the paint shop this week. So I hope to be putting it all back together next weekend. I will try to post some pics of the proceedure and finished product.
1984 - Porsche 944
1994 Grand Cherokee
Old 07-12-2002, 07:05 PM
Crippler's Avatar
Just read that you are supposed to set the engine at TDC - 10 degrees. Any thoughts on this? Is TDC not right?
1984 - Porsche 944
1994 Grand Cherokee
Old 07-12-2002, 09:29 PM
Scott R's Avatar
This is correct, when you install the new cam belt drop 10 deg, or 1 and 1/2 teeth. This way when you tension the belt it hits the mark perfectly.
2021 Model Y
2005 Cayenne Turbo
2012 Panamera 4S
1980 911 SC
1999 996 Cab
Old 07-13-2002, 12:06 AM
No, you do NOT install the timing belt with the crank set at - 10deg from TDC. ALWAYS install the belt at TDC.
Setting the crank back 10deg is for adjustment purposes only.
Re-read your manual.
From November 2012; Precision Porsche Specialist
Sussex UK, +44 (0)1825-721-205
2001-2012 Gerber Motorsport Inc. 206-352-6911
07.15.06 1996 Ducati 900SP. Suprisingly enough, it's red
08.16.09 1999 Kawasaki ZRX1100. Green.
Old 07-14-2002, 11:10 AM
