944 Trunk Release Won't Cycle
So on my last 944 I remember the electronic trunk release would cycle once per press of the drivers footwell release button. Current 944- the release motor runs as long as you hold the button. Contacts look good, unless the circled part is actually a broken contact (edit: is NOT a broken contact)
"Ad astra per aspera" Last edited by 86Meesta2; 04-11-2013 at 09:54 PM.. |
Fixed! Culprit was actually the release switch itself- the momentary contact was not properly switching between the poles. Solution was to slightly bend contact back into proper shape, not too much or you'll short it out (I burned one fuse up)
"Ad astra per aspera" |
AFM #725
It's not supposed to go the whole time? lol...
Watchdog Armory Racing AFM #725 Thanks to my 2017 Sponsors: JPH Suspension | AXO | Armour Bodies | BELL Helmets | Braven | EVLUTION Nutrition | Forcefield Armor | FunTrackDayz | Galfer | Motion Pro | MOTUL | Matrix Racing Concepts | ODI Grips | OGIO | Shorai Inc. | SPEEDMOB | Vortex | Woodcraft | Wicked Audio http://www.gawerracing.com |
The motor is supposed to cycle once when you press the release button- mine was just running as long as you pressed the button. Problem with that is you don't have positive control over where in the cycle the motor stops i.e. it could stop in the released position... definitely leaves potential for the hatch to come flying back up when you get on the highway after not realizing that it didn't latch. Properly operating, the motor automatically stops in the latched position
AFM #725
Oh, makes sense. How should I repair this...?
See above Pop everything back into place
Do as you like ,its just me putting my car on a diet,if its not needed its gone ![]()
1985 944 2.7 motor,1989 VW Corrado 16v,57 project plastic speedster t4 power,1992 mk3 Golf,2005 a4 b7 qt avant 3.0 tdi,1987 mk2 Golf GTI,1973 914,2.2t to go in. Past cars, 17 aircooled VW's and lots of BMW's KP 13/3/1959-21/11/2014 RIP my best friend. |
Triple T
Thanks for the info. I thought mine was supposed to cycle continuously!
![]() However, the picture you show is of the release motor in the rear hatch. Is it the motor that needs adjustment (as per picture) or the tip switch at front drivers side well? |
At first I figured that the motor was at fault- wondering if the piece circled was a broken contact. It was not. The culprit in my case was only the switch at the drivers side well.
Wow, my switch has done this ever since I bought my car. I always just assumed that was how it was supposed to be.
Another project added to the list!
1990 S2 Coupe |
