DBF DBF is offline
How do you remove the wire harness from fuse box?
I need to replace a few burned wires from the wiring harness, and can't figure out how to remove the harness from the bottom of the fuse box. Any advice? Thanks.
Old 06-07-2013, 05:31 PM
mhariush's Avatar
Well, you cant. You can unplug the fuse box but you wont get the harness out through the hole. You'll need to pull it out from inside the car. I just did it on a parts car.
This is the harness in its entirety. It's massive.
which wires are you trying to replace?
Current: 87 944S Black/Black, 89 944 Turbo S ANDIAL White/Burgundy, 78 924 Black/Black, 17 Cayenne S, 03 Turbo X50 Aero
instagram @mhariush http://stores.ebay.com/Techniker-Parts/
Old 06-07-2013, 06:08 PM
944 addict
mytrplseven's Avatar
Send a message via AIM to mytrplseven
what year is your car?
3 944's, 2 Boxsters and one Caman S, and now one 951 turbo. Really miss the Cayman.
Some people try to turn back their "odometers." Not me. I want people to know 'why' I look this way. I've traveled a long way and some of the roads weren't paved.
Old 06-07-2013, 06:37 PM
mhariush's Avatar
Old 06-07-2013, 06:38 PM
mhariush's Avatar
And it was a pain in the ass to get out. I had to disconnect the steering rack to get the big chunk of wires out and it goes under carpet and sound proofing and everywhere...
Old 06-07-2013, 06:43 PM
DBF DBF is offline
I have an 89 S2. I have the dash off the car so have good access to the bottom of the fuse box. The problem I'm having is getting the sub-harnesses out of the fuse box. There isn't an obvious tab that holds the sub-harnesses to the fuse box, and I have to replace a several bad wires starting at the fuse box. Thanks.
Old 06-07-2013, 08:31 PM
mhariush's Avatar
Ah, pull the fuse box up from the engine bay, pull it good and twist it and you'll have access to and can disconnect the harness. But make sure you disconnect the battery first...
Old 06-07-2013, 09:03 PM
DBF DBF is offline
I've got the fuse box pulled up and have access to the bottom, but something is holding the individual sub-harnesses in place. I don't see a latch or clip, so what's the secret for pulling the sub-harness out of the fuse box? Thanks.
Old 06-07-2013, 10:39 PM
mhariush's Avatar
Hmm. I don't recall, so I don't think it was anything special. Just have to wrestle it out, gently I think. I just did it, a month or two ago...
Here's the fuse box without the wires, if that helps you see it from different angles...
Old 06-07-2013, 10:48 PM
Dave Colangelo's Avatar
there is a center mechanism that holds all the big clips on. There is a small tab in the center of the front of the fuse panel (see above pic). Pull that tab out and it will fee the latch slider on the inside of the large connectors. There is a small clip on the outside edge of the connector gently pry this away but careful not to crack them, and remove the connector.
Regards
Dave
'78 911SC Targa (Back In Action!)
'00 996 Carrera (New kid on the block)
'87 944 (college DD - SOLD)
'88 924s (high school DD - Gone to a better home)
Old 06-07-2013, 10:50 PM
mhariush's Avatar
Regards
Dave
Ah, yes Dave. It's good that some remember. It's coming back to me now.
And it is this one
Old 06-07-2013, 10:54 PM
DBF DBF is offline
That did it. Thanks everyone. Now I just got to find a place that sells the proper connectors - hopefully they'll have them at my nearby radio shack.
Old 06-08-2013, 12:04 AM
mhariush's Avatar
Well, I have the complete harness, but I'd have to sell it as one piece.
This looks like a good one to pick apart maybe?
1990 Porsche 944 S2 Cabriolet Convertible Wiring Harness Dashboard Fuse Box | eBay
Old 06-08-2013, 12:07 AM
