Help identifying possible 944 parts please
Hello all,
I recently purchased some parts and there are some items I just can't identify. I have spend hours looking through Porsche PET but am struggling to find these parts and their potential part no's, any help greatly appreciated. I am not sure if they are all 944 parts but thought this was a good place to start. thanks in advance, ![]() ![]() ![]() ![]() ![]() ![]() ![]()
Challenge your limits, don't limit your challenges 911 RSR Jagermeister replica (Sold) 1987 944 Turbo cup (Sold) |
The second to last one is the brake pad sensor. The others, not sure. Also hard to tell in the picture, too much contrast in them to make out details and shape. and also materials.
Current: 87 944S Black/Black, 89 944 Turbo S ANDIAL White/Burgundy, 78 924 Black/Black, 17 Cayenne S, 03 Turbo X50 Aero instagram @mhariush http://stores.ebay.com/Techniker-Parts/ |
Appreciate the help, 1 down, many more to go
Frankly my dear....
Second photo down shows some rubber seals. Don't recognise all of them, but the top one could be the piping that goes on the top of an oval dash instrument binnacle to seal it to the main dashboard assembly 999 911 320 40. The third one appears to be the glove box rubber gasket 944 552 035 00.
Forth photo shows a bracket, I seem to recall seeing that type around the radiator lower shroud. Last photo - pipe clips for brake, fuel, vacuum pipe..?
Porsche - accept no substitute Blue 1999 Boxster - Brief encounter! Black 1988 944S - Ongoing project Black 1987 944S - Gone but not forgotten Metallic Black 1980 924 - Those were the days.... Red 1979 924 - Hmm Minerva blue 1979 924 - Where it all began! |
Here are my best guesses. Maybe some pictures with aspect may half idenitfy more?
#3 cover for the sunroof motor take this back, not what that is. #4 bracket for afm? #5 dme cover/panel 944 551 149 02 #6 headlight motor bracket 477 805 622 or 617 (for left or right) #7 Brake sensor #8 clips for hardlines, a/c or brake depending on diameter Last edited by Shifter; 06-13-2013 at 01:35 PM.. |
1988 944 2.5L 8-v NA 301k
Don't all (well, virtually all) Porsche oem parts have a 944.xxx.xxx part stamp ?
'88 8v n/a 301k with 41k on current TBelt M454 M533 M650 M425 M418 ![]() New Feb'13 Bridgestone Grid 019.. awesome. Paid just $1,700 running & inspected. Big RUSH Fan! Lic Plate = LIFESON |
Thanks for feedback guys will check them out on PET in the am and see what I can find with your guidance and report back.
Again thanks for the help everyone
Bracket near the radiator is part no 477 971 881 B looks similar but I don't know if it is same one as there seems to be an extra hole see what you think. Any idea on part no for the pipe clips as I am struggling to find it on PET Thanks again
# 4 what is afm?? # 944 551 149 02 comes up as foot support on PET and doesn't seem to match photo #6 477 805 622 does seem to match the photo against PET, one on PET seems to have a bend in it and different holes? # 7 agreed thanks # 8 any idea on potential part no
The part in the last photo is the clip that holds the Auto Trans hard lines in place. There are two of them mounted on brackets that are held in place by cam cover bolts and one all the way back at the trans.
Part # - 999 511 121 40 Part number 3 Porsche 944 Oil Cooling Parts Last edited by jeffrsmith; 06-14-2013 at 05:26 AM.. |
AFM is the Airflow Meter, but I don't think that's what it is. I just swapped the AFM on my car and it doesn't look familiar. But, I've heard there's two different versions of the bracket, is that correct? So I could be wrong
Thanks not sure about different brackets
#4 is a bracket for the rear fog light on an older 911. My 83SC has one.
Lorraine 83 SC CAB RoW 2003 C4S coupe 07 BMW R1200RT 76 BMW R90S 76 BMW R60/6 |
Another one down many more to go
