944 addict
mytrplseven's Avatar
Send a message via AIM to mytrplseven
New idle issues
I was chasing a stumbling engine issue on acceleration. I just replaced the TPS and made sure it's adjusted correctly. After putting all the intake back together, the car runs like it should, with one small issue. the idle is now at 1200 with the A/C off and at 900 or so with it on.
I've read some past posts about engine idle issues and wonder if anyone has any other light to shed on why it would be higher, why the split of A/C on or off and finally I suspect I can adjust the screw on the TB to bring it down.
I'm still concerned about why it's all changed after the TPS was replaced. Also listed on RL.
3 944's, 2 Boxsters and one Caman S, and now one 951 turbo. Really miss the Cayman.
Some people try to turn back their "odometers." Not me. I want people to know 'why' I look this way. I've traveled a long way and some of the roads weren't paved.
Old 07-02-2013, 01:20 PM
Automotive Necromancer
SolReaver's Avatar
Send a message via Skype™ to SolReaver
idle set screw
The idle speed set screw (bolt?) has been known to loosen itself up and bring the idle up. If it is steady and healthy, just adjust it with a fully warmed engine to about 850. (a warm purrr).
A glop of RTV or other sealant will hold it in place once you have it where you want it.
There may be nothing quite as expensive as a cheap Porsche: Ruby Red 84 928S : White 87 924s 2.5L NA (Blinky) M44/07-43H10676 spoiler delete - 046/2B - Belts 9/12, Clutch and OC seals 8/08 andd Red 94 Del Sol: Please put your Make, Model and Year in Sig. Try not to break more than you fix.
Old 07-02-2013, 02:40 PM
AFM #725
Gawernator's Avatar
Probably the adjustment screw on throttle body pal
Watchdog Armory Racing AFM #725 Thanks to my 2017 Sponsors: JPH Suspension | AXO | Armour Bodies | BELL Helmets | Braven | EVLUTION Nutrition | Forcefield Armor | FunTrackDayz | Galfer | Motion Pro | MOTUL | Matrix Racing Concepts | ODI Grips | OGIO | Shorai Inc. | SPEEDMOB | Vortex | Woodcraft | Wicked Audio
http://www.gawerracing.com
Old 07-02-2013, 04:06 PM
944 addict
Thing is, this all started after replacing the TPS and immediately after warming up the motor. I'm also curious as to why there's a difference of around 300 rpm between A/C on vs off. I see the adjustment screw and don't necessarily want to mask another problem by adjusting it down with that.
Old 07-02-2013, 05:42 PM
