Heater Bypass Help
Hi everyone,
I'm in the process of bypassing the heater. I'm at PR and I don't need it never.
Can I put a hose directly from the steel tube above the exhaust to the water intake in the back side of the head?
I plugged the steel tube once, but pressure keeps rising and melted the plastic cap.
Any help is welcome!!
Old 07-10-2013, 08:27 AM
9FF 9FF is offline
9FF's Avatar
The problem with a hose is it could easily chafe back there and leak and the reason the plug you put on the steel tube failed is because you used plastic. There is no pressure in that tube to cause the cap to fail, the steel tube is a return line to the water pump. To do it right...
Buy or make one of these and block of the water passage to the heater control valve at the back of the head. Then remove the steel pipe and fit a rubber bung on the water pump where it used to lead to. Make sure you use a rubber bung made for coolant systems, normally available at any auto parts store. GL
Mike A
9TECHNIK | TRANSAXLE ÄRA
1986 944 (Street); 1986 944 (Track); 1986 951; 1989 951 (3.0L 8V); 2000 996 Cab.
Old 07-10-2013, 09:43 AM
If there's no pressure on the steel tube, why it had lost a lot of water via that way when the plastic cap broke?
There's another problem on the system causing pressure going that way? Too much water on the system?
When I bought the car, a plastic cap was used on the outlet of the heater valve. That one broke when I changed the reference sensors. The I decided to plug it at the steel tube.
By the way are you telling then, it's possible that the head is already blocked. I'll see this afternoon.
Old 07-10-2013, 09:51 AM
9FF 9FF is offline
9FF's Avatar
Water flows from the back of the cylinder head through the heater valve and heater back through that steel pipe to the water pump. So if you block off the water pump with a rubber bung the pump isn't pumping water to the bung, its going the other way.
Then you need to fit that metal blanking plate at the cylinder head to stop water feeding the heater circuit.
Old 07-10-2013, 05:35 PM
porschetub's Avatar
Originally Posted by onedroppr View Post
Hi everyone,
You will have no windscreen demister,wouldn't that be a hassle?
1985 944 2.7 motor,1989 VW Corrado 16v,57 project plastic speedster t4 power,1992 mk3 Golf,2005 a4 b7 qt avant 3.0 tdi,1987 mk2 Golf GTI,1973 914,2.2t to go in.
Past cars, 17 aircooled VW's and lots of BMW's
KP 13/3/1959-21/11/2014 RIP my best friend.
Old 07-11-2013, 01:08 PM
sjv sjv is offline
I filled a 1/2" copper plumbing pipe W/ soulder half way total leaght 1.1/4 "then installed in rubber hose just in frount of solid 1/2 pipe above exshust manifold stopped all leak by did'nt fill plug all the way so I could remove latter W/ needle noses
Old 07-13-2013, 06:15 AM
