Champagne on Beer Budget
HelmetHead's Avatar
87 924s rough acceleration when cold
Car starts just fine but when you quickly rev the engine with no load, it stumbles and almost falls on it's face...then it will catch back up and wind up. Once the car is up to operating temperature it runs great...throttle response is peppy as it should be??
Things I've done so far..
I took the AFM apart and did the voltage testing (per clarks-garage)...I notice that there was zero voltage coming into my meter when the flapper is completely closed and up to about 10% throttle when working the slider by hand. When I rotate the slider beyond 10% the voltage starts to increase as desired. I then put the AFM back on the car with the top open and noted the position of the slider at idle..it is just beyond the 10% area and would lead me to suspect that the AFM is functioning as intended.
TPS sensor checked out good on ohms for both closed and WOT.
Has anyone else experienced the lack of voltage through their AFM at fully closed (zero airflow) position or is this normal...clarks writeup indicates voltage should be evident throughout the entire slider rotation?
Only thing I didn't verify was the AFM temperature sensor resistance level but I will check that later today.
any suggestions or ideas would be greatly appreciated.
Einar
www.einarsgarage.com
Instagram @einars_garage
https://www.facebook.com/pages/Einars-Garage/375533809160797
Old 08-02-2013, 09:25 AM
944 addict
mytrplseven's Avatar
Send a message via AIM to mytrplseven
If this is temp related, I'd look at the temp sensor that goes to the DME. They're cheap and that's the first place I'd go.
3 944's, 2 Boxsters and one Caman S, and now one 951 turbo. Really miss the Cayman.
Some people try to turn back their "odometers." Not me. I want people to know 'why' I look this way. I've traveled a long way and some of the roads weren't paved.
Old 08-02-2013, 10:14 AM
AFM #725
Gawernator's Avatar
+1 DME Temperature sensor. Blue connector
Old 08-02-2013, 10:58 AM
Paul_Heery's Avatar
I agree. Most likely the DME Temp Sensor. Clark's as a write upon how to diagnose.
DME Temperature Sensor Testing
HelmetHead's Avatar
Thanks Guys! Will verify function of DME temp sensor with meter later today and report back.
TGIF and Cheers!
Einar
Old 08-02-2013, 11:00 AM
