Yeeehaaaa! Like you said, "it's always the simple things".
Spent the afternoon looking for excuses to drive places:) Was a nice warm roof down kinda day.
Oil pressure looked good. About 4.5 bars at idle when cold and after it was totally warmed up just slightly below 2 bars. When touching the gas at all up to 4 or 5 bars. One of the times I started it, it took about 5 seconds to get oil pressure which is a bit worrisome so obviously I will continue to watch it carefully. Temp was perfect, Only see one leak from the top rear of the engine which I have always had and did not address this time. Otherwise the plastic I have under the car is clean. Going to try to get an appointment for an alignment early this week so that I can do some highway driving next weekend. Thanks for all the help and advice. Mark |
Sounds like that cork gasket on the rear end of the cam tower. Easy to fix...don't overtighten it.
| All times are GMT -8. The time now is 04:01 AM. |
