alan6272's Avatar
what mods, changes , have you made
what changes , mods, improvements that you have made to you car which was an improvement?
1983 944 ,1983 V-65 magna
catalina22 sold
baja ski boat sold
my toys
Old 09-07-2013, 07:16 PM
Volhv's Avatar
I have an 86.
Early steel control arms
Manual steering rack
Removed PS pulley from crank (who needs light weight pulleys when you can just remove them)
AC delete
Steel heater control valve
Turbo sodium filled exhaust valves (they were the same price as the NA ones)
Larger Turbo radiator
Titanium heat shield above exhaust manifold
Aeroquip Firesleeve on fuel lines
SS braided brake lines (only did the fronts, back ones are on the to do list)
Hella E-code headlights
Homemade stainless swaybar to crossmember stiffeners
Only944 short shift
Silicone vacuum lines
Cockpit sound-deadening delete
That's all that comes to mind.
1986 944 NA Sapphire Metallic
http://944porsche.blogspot.ca/
Old 09-07-2013, 09:14 PM
AFM #725
Gawernator's Avatar
Lol can I just take a picture of the receipt binder?
Old 09-07-2013, 11:30 PM
Chunkerz's Avatar
I have the NA-Tune, stainless steel braided brake lines, turbo bumper/related items, throttle response cam, stainless steel braided fuel lines, Porsche crest shift cap, and that's all I can think of at the moment. Coming soon are some Koni struts/shocks, 300lb front springs, 29 or 30mm torsion bars (I think that's what I decided on?), those Cup 4 rims from Tire Rack, Only944 short shifter, and a few other small unimportant items.
Old 09-08-2013, 01:03 AM
tamathumper's Avatar
Are we talking about an improvement in speed/cornering, or just a general improvement? In no particular order, a partial list includes:
D1R Stage 3 Supercharger
D1R lower strut brace
D1R upper strut brace
D1R firewall brace
D1R chassis brace for cabriolet
KLA sway bar braces
D1R short shift kit
D1R exhaust manifold heat shield
D1R stainless clutch hose
Higher Connections full cable kit
Boxster S II wheels, 17"
Kenwood DNX6140 DVD/NAV/BT Unit, all new speakers
XPel headlight/fog lamp/turn signal lamp protection
Probably the biggest improvement was the double-DIN stereo. That added at least 30 b(s)hp.
'78 924 "NA"
'87 944 "S"
'93 968 "SC"
Old 09-08-2013, 04:25 AM
I've always wanted to write out my mod list for my 1984:
AIR Fibreglass "Turbo" nose
AIR Fibreglass rear bumper
Rogue Tuning "NA Tune" Maf Conversion
86 Turbo rear alum. suspension conversion(early cars have steel arms)
28 mm Torsion bars
Weltmeister spring plate bushings
89 Turbo S sway bars
Koni yellow shocks
Ground control coilover sleeves w/300lb spings(fr)
Lowered
manual headlight conversion
installed my tach in the middle of the gauge cluster, moved the speedo to the right
7" steering wheel hub extension
Momo prototipo steering wheel
VDO voltage gauge
Stereo/speaker/antennae delete
rear seatback delete
rear carpet from an 86 installed(much nicer)
Lindsey racing oil pan baffle kit
Hawk "Blue" brake pads
Windshield washer bottle delete
Sparco Evo race seat/Corbeau Forza pass. seat
fire Extinguisher installed in front of Pass. seat
Dansk SS cat-back exhaust
hatch from an 86(no separation)
rear wiper delete
hatch release delete
spare tire/jack delete
alum. pedals
"Only 944" short shifter
"Only 944" shifter
"Only 944" Soft cupholder
LSD Transaxle
Aftermarket VDO temp. gauge
86 sunvisors
A/C delete
Toyo R888 225/50/15 tires on Cookie Cutters painted all black.
S/S brake lines
Brumos Porsche licence plate surround
Parts I have bought but not installed - Coming soon:
MDS 4-1 Header
AEM UEGO Wideband O2 sensor and gauge
Eaton M90 Supercharger
New OEM 951 Injectors
Fibreglass Hood
here's a couple of pics:
Old 09-08-2013, 05:32 AM
H.F.944's Avatar
944/I, 1984 ROW (look at my garage)
Turbo Look,
Koni Shocks
951-Swaybars
Fuchs
NA-Tune
CamKey +4°
MSDS-Header
Front Muffler deleted
coming soon 254° camshaft or at least a "late" camshaft.
At first I'm looking for an nice used 254° camshaft, any offers are appreciated.
Old 09-08-2013, 10:54 AM
944 addict
mytrplseven's Avatar
Send a message via AIM to mytrplseven
2006 Cayman (base model) 17" wheels w/BFG G-Force radials/crest center caps
short shifter from Only944.com
Throttle response cam
Bilstein shocks and inserts
Momo Race Steering wheel w/Porsche logo horn button
Stainless Steel brake lines
Sachs clutch package
New dash
Complete Blaupunkt San Francisco sound system & speakers
All engine & transaxle seals
Belts, rollers water pump
swaybar bushings
gauge light rebuild
"and on the eigth day, he rested".....
3 944's, 2 Boxsters and one Caman S, and now one 951 turbo. Really miss the Cayman.
Some people try to turn back their "odometers." Not me. I want people to know 'why' I look this way. I've traveled a long way and some of the roads weren't paved.
Old 09-08-2013, 12:18 PM
Non Compos Mentis
944NA: Ripping out the interior, welding in a roll cage, putting big numbers on the doors.
......plus a few engine and suspension mods.
944S: Tossing out the ugly Phone dials, replacing them with Fikse wheels & wider tires.
Old 09-09-2013, 06:29 PM
