-   -   86 944 speed cross reference sensor bolt? (http://forums.pelicanparts.com/porsche-924-944-968-technical-forum/775115-86-944-speed-cross-reference-sensor-bolt.html)
Rod Schneider 10-09-2013 07:33 AM
Originally Posted by uvachief (Post 7696146)
Fiddle flarn fiddle! No access panel hunh? Why is that hole there on the first place? Release heat? They could have vented it toward the sides.
That hole is where the Top Dead Center indicator is for setting the cam timing. At the very least, pull the starter and fish around inside the bell housing to try and find that bolt. Bad things can happen if it gets caught in the flywheel or clutch.......
uvachief 10-09-2013 09:05 AM
