Mike_944's Avatar
I started making the parts list...
This is my parts list so far for my 1987 944S.
Feel free to add anything you think I would need to get this to be a dependable amazing looking/running car!!
944S Restoration Parts/Cost
Engine
Cooling System - http://www.***********/store/cart.php?m=product_list&c=3780
Belts/Rollers
Exterior
  • Rear Valance - $120?
  • Front Splitter - $55
  • Tint - $140
Paint
  • Exterior Paint Complete - $450
  • Powder Coat Rims - $175?
  • Powder Coat Intake/Cam Cover - $120?
Interior
  • Reupholster all seats - $500
  • Dash - $100
  • Mats - $90
  • Steering Wheel - $130
  • Hub - $60
Plus about 109380325832 hours of my labor....if I don't break anything.
2002 E46 BMW ///M3 (Daily)
1987 Porsche 944S (Project)
1985.5 Porsche 944 (Sold)
Old 11-13-2013, 06:48 PM
AFM #725
Gawernator's Avatar
$175 for four wheels? Man, that's cheap... places here want like $70/wheel and I talked him down to $60..
Watchdog Armory Racing AFM #725 Thanks to my 2017 Sponsors: JPH Suspension | AXO | Armour Bodies | BELL Helmets | Braven | EVLUTION Nutrition | Forcefield Armor | FunTrackDayz | Galfer | Motion Pro | MOTUL | Matrix Racing Concepts | ODI Grips | OGIO | Shorai Inc. | SPEEDMOB | Vortex | Woodcraft | Wicked Audio
http://www.gawerracing.com
Old 11-13-2013, 08:46 PM
Converted 944 Guy
You'll probably need the small fuel damper line as well (diaphragm to fuel rail).
944 110 413 02
And the oil cooler seal kit...and alignment tool.
Old 11-13-2013, 08:48 PM
GostRidr's Avatar
Definitely gonna love following this project as I hope it is in my future. What is the inspiration for getting to this now? Also following your smog/horse power upgrades.
Good luck!
peter
1991 944S2 Cab, Crystal Silver Metallic "Platinum Banshee"
1987 944S Alpine White, Ice Shark Lights "Desert Ghost"
2015 Charger R/T Road & Track
Old 11-13-2013, 09:11 PM
mhariush's Avatar
I'd replace the coolant Temp Sensor while I was in there (928-606-201-01-M82). And might as well replace the ICV too, I've had a leak on two different ones on my S. They are getting old.
Also new Genuine motor mounts. I got a set of aftermarket ones, but I'll go and redo them with the genuine.
What's your strut condition and which set up do you have? If you have the M303 get them rebuilt at TruChoice and get new ones for the rear. And replace the ball joints on the control arms and the tie rods while you're in there.
Also do the oil cooler and change the o-rings on the oil pressure relief valve since you'll be in there...
And, in the head on the S there's another oil pressure relief valve that's locked in with a set screw. It's located on the bottom left corner if you're looking down at the head from the passenger side. Change the o-rings. I have an extra set you can for $10 shipped. They don't sell the o-rings separate, I had to chase down the right size and spec.
And change the O2 sensor. You can get the Universal Bosch one and solder the wires together. Save a ton of money.
Current: 87 944S Black/Black, 89 944 Turbo S ANDIAL White/Burgundy, 78 924 Black/Black, 17 Cayenne S, 03 Turbo X50 Aero
instagram @mhariush http://stores.ebay.com/Techniker-Parts/
Old 11-13-2013, 09:51 PM
Mike_944's Avatar
Yea luckily I know a guy. Another guy I talked to said $75 a wheel and I said no. haha
944 110 413 02
I already replaced that line but I forgot about the oil cooler seal kit! Thanks!
Good luck!
Well I've been saving up some money so I can get as much done at once as possible.
I definitely want some kind of power upgrade since I'm doing all this work so I will be exploring my options!
The coolant temp sensor is on the list! lol
I'm going to hold off on suspension for the moment as I want to do them right and get a good setup. The front struts are yellow so I'm guessing konis?
I will let you know about the o-rings once I start ordering parts.
Thats a good idea for the O2 sensor. Is that an easy job?
Old 11-13-2013, 10:09 PM
GostRidr's Avatar
02 is VERY easy for someone that is doing what you are doing! A little tricky on getting a wrench to access it as the sensor attaches directly to the top of the exhaust. Wire then rises up into the harness for an easy connection. I did the universal solder/splice that M refers to.
peter
Old 11-13-2013, 10:13 PM
Mike_944's Avatar
I haven't done most of this stuff. I'm more learning as I do it. haha I'm also trying to gauge how low certain things will take me.
I'm going to drop the whole exhaust so that might make it easier!
Old 11-13-2013, 11:26 PM
curtisr
curtisr's Avatar
1977 924 Guards Red (parted and sold)
1987 924s Alpine White (sold)
1987 924s Kopenhagen Blue (my Lowencash tribute track car -- sold)
1987 924s Garnet Red (currently becoming Lowencash II)
1982 928 Silver (sold)
Old 11-14-2013, 02:56 AM
When you do the FOES, you will likely need to drill out the Cam Bolt. Just a couple of dollars for a replacement so add it to your list. Great write up on the FOES here:
Front Engine Seals
Don't forget about the special tools if you don't have them already...
Old 11-14-2013, 04:20 AM
mhariush's Avatar
+1 on the new cambolt, that cheese head strips like crazy.
Also, there's two sensors in the block. One is the DME temp sensor the other is the coolant temp sensor, one is 20 and the other is 40. Replace both while you're there.
Old 11-14-2013, 08:34 AM
Endat's Avatar
Can't go wrong with all new hardware
944 General Purpose Fastener Kit
2001 Porsche Boxster
1987 944S
Old 11-14-2013, 09:54 AM
Frankly my dear....
rhett's Avatar
Well Mike, I think perhaps you are being a bit conservative with your time estimate there as everyone knows it takes a lot longer than 12 million years to do all the work you are proposing...
You really are going to town on this project..look forward to many a post in the future (with loads of pictures too).
Oh..by the way..stuff will break, its the nature of the beast!
I wish you well and good luck!
Porsche - accept no substitute
Blue 1999 Boxster - Brief encounter! Black 1988 944S - Ongoing project
Black 1987 944S - Gone but not forgotten
Metallic Black 1980 924 - Those were the days....
Red 1979 924 - Hmm Minerva blue 1979 924 - Where it all began!
Old 11-14-2013, 11:35 AM
mhariush's Avatar
That fastener kit looks very good endat, did you get it? Have any pics of it? I might get that, been thinking about plating bolt myself...
Old 11-14-2013, 12:34 PM
Originally Posted by curtisr View Post
Nice, but a little too much bondo for my taste.
Old 11-14-2013, 02:09 PM
tamathumper's Avatar
LO-fricken-L.
'78 924 "NA"
'87 944 "S"
'93 968 "SC"
Old 11-14-2013, 03:06 PM
Mike_944's Avatar
I saw this when I was in class and started laughing out loud like an idio. haha
That looks sooooo awesome. I'm one of those guys that replaces every single bolt I take off my car.
Thanks!! I'm really excited. I hope I can do i as I've never rebuilt an engine before. Half these parts I never knew existed in a car!
hahahaha
Old 11-21-2013, 12:46 AM
1988 944 2.5L 8-v NA 301k
VirginiaF1's Avatar
Engine
[LIST][*]Head Work- ? [*]Crank Balanced - ?
Howdy..
Inspriring to hear of your restoration efforts for these fine motorcars.
Apart from the Crank and Head work yet to be priced, your running parts total exceeds $4,000...
Once all of this is complete, how will the re-sale price be impacted?
(Asking anyone who posts)
I realize that selling a restored 944S is not on your to-do list, but I ask merely to understand the market valuation of making our cars nearly like-new..
eg: Is the resale axion something like: 40% of parts restoration money comes back if car is re-sold within 6 months.. or whatever.
Good luck and kudos!
mikey
'88 8v n/a 301k with 41k on current TBelt
M454 M533 M650 M425 M418
New Feb'13 Bridgestone Grid 019.. awesome.
Paid just $1,700 running & inspected.
Big RUSH Fan! Lic Plate = LIFESON
Old 11-22-2013, 06:59 AM
Sadly, resale value will, IMHO, be impacted very little by this or virtually *any* work on P-cars of this age in otherwise "very good" condition.
'78 924 "NA"
'87 944 "S"
'93 968 "SC"
Old 11-22-2013, 07:49 AM
VirginiaF1's Avatar
Porsche Crest
Howdy Tama..
Oh, How I wish Peart still played Tama's..
Your sig indicates 3 P-rides, has resale after repairs really been independent of replaced parts/investment.. sheesh.
I guess our solace is knowing we did our part to further the life of our vintage classics.
Thanks for the chime.
Peace
mikey
Old 11-23-2013, 12:43 PM
Tags
engine , paint , parts list , restoration
