mhariush's Avatar
How to remove rear Hub and Brake Rotor when trail arm is not installed on car?
Being an idiot I removed the rear suspension from my parts car but didnt remove the hub and brake rotor when I could have done with the handbrake on.
So...Now I can't find a way to remove it. The 32mm nut is really tight and no matter how I try to brace the rotor with a bar I can't get enough force on it without it moving on me, one way or the other...
Any suggestions?
Also, how the heck do I pop off the tie rod ends and the ball joints on the front control arms? I have these two things but I can't get it off, not sure if I'm using them right, or enough...
Current: 87 944S Black/Black, 89 944 Turbo S ANDIAL White/Burgundy, 78 924 Black/Black, 17 Cayenne S, 03 Turbo X50 Aero
instagram @mhariush http://stores.ebay.com/Techniker-Parts/
Old 10-23-2013, 10:14 PM
Go to a shop and have them hit it with a 3/4" impact wrench
Old 10-23-2013, 10:39 PM
mhariush's Avatar
good idea. how many rpms ft/lbs should that be? i have a compressor, maybe its time to get an impact wrench...
Old 10-23-2013, 10:41 PM
In the Fires of Hell.....
kdjones2000's Avatar
Ball joints are just clamped by the nut on the spindle. Loosen the nut and remove the bolt and things should separate easily.
I use a tie rod fork to remove mine, but you should be able to get those with the tools you have.
PCA Instructor: '88 951S - with LBE, Guru chips, 3Bar FPR, 1.3mm shimmed WG, 3120 lbs, 256 RWHP, 15 psig boost
Old 10-23-2013, 10:52 PM
AFM #725
Gawernator's Avatar
I hammered my tie rods out with a REALLY BIG BFH
Watchdog Armory Racing AFM #725 Thanks to my 2017 Sponsors: JPH Suspension | AXO | Armour Bodies | BELL Helmets | Braven | EVLUTION Nutrition | Forcefield Armor | FunTrackDayz | Galfer | Motion Pro | MOTUL | Matrix Racing Concepts | ODI Grips | OGIO | Shorai Inc. | SPEEDMOB | Vortex | Woodcraft | Wicked Audio
http://www.gawerracing.com
Old 10-23-2013, 11:34 PM
the top tool works great for the balljoints but be aware it makes a HUGE popping sound which sounds like you just broke something.
for the hub nut youre gonna need a BFimpact gun. if its electric, skip the battery and just plug it into some uranium for max power
Old 10-24-2013, 06:18 AM
mhariush's Avatar
I have a 1/2" 230 ft/lbs wrench, will that do the trick or need something more powerful?
Old 10-24-2013, 12:34 PM
White and Nerdy
Tervuren's Avatar
I do not think that that will get it done, but with a helico lube or such, and a lot of time, maaaybe.
I did it on the car, without the parking brake, and a 1/2" drive torque wrench, I would slam the wheel opposite the torque wrench, and was able to get it off after a few tries of penetrating lube soaking. The torque spec to tight it to is near 300ft/lb's IIRC, add in rust and adhesion, and its gonna take a lot to get it to loosen up.
Shadilay.
Old 10-24-2013, 12:46 PM
mhariush's Avatar
they have an air 700 ft/lbs at HF for around $70 now...maybe I'll give that a try.
Old 10-24-2013, 12:49 PM
AFM #725
Gawernator's Avatar
Gl!
Old 10-24-2013, 01:05 PM
mhariush's Avatar
thanks lesson learned, do it while on the car next time...
Also learned, drop engine from below, drop front suspension.
I'm sure there are other things I learned too, but can't remember them right now haha.
Old 10-24-2013, 01:12 PM
honerboys's Avatar
if the calipers are still attached try locking the rotor by inserting an open end into the vanes between the two rotor braking surfaces (cooling slot)
84 928 S - SOLD
2012 Cayenne S
Old 10-24-2013, 05:28 PM
