Converted 944 Guy
Timing & FOES Parts List Help
Below is my parts list for timing/balance belt/water pump and front engine reseal. 86 944 NA with updated WP.
From Pelican Front engine reseal kit- 10-0507-098-M260 Oil pump sleeve- 944-107-161-02-M260 O-ring oil pump sleeve - 999-707-283-40-M213 Cam housing seal - 928-105-184-00-M260 Crankshaft seal - 999-113-268-40-M17 WP gasket - 944-106-132-04-M17 Thermostat & seal- 944-106-019-00-M2 Thermostat spacer - 900-234-160-00 Thermostat seal - 944-106-929-08 Thermostat snap ring - 900-042-025-01 PS belt - 999-192-236-50-M21 Alt/AC belt - 999-192-299-50-M21 From Zims Timing belt kit Cam/Balance Shaft Belt & Roller Kit, 944 -86 (late) Water Pump Remanufactured Water Pump, Late Version, 944 83-86 Water Pump Block Off Waterpump Fitting/Block Off Plate, 944 all WP hardware Hardware Kit for Waterpump Installation I will also do the radiator hoses. Also, the arnnwork tool kit. Can some of you experienced guys review and let me know if I'm missing anything? Thanks. |
I think you have it all covered..
You will need a flywheel lock, Pelican has it. And while the manual does not call for anything on the WP gasket, I would smear some Hylomar on it. I didn't the fist time, and it leaked. Did not risk it the second time. If you shear off the water pump studs when trying to remove them, get some M6 timeserts. One more piece of tribal knowlege......... don't drain the rad by removing the drain plug unless you have a new one handy. And there are two types of plugs blue (coarse thread) or black (fine thread).
1986 944 NA Sapphire Metallic http://944porsche.blogspot.ca/ |
Converted 944 Guy
Proprietoristicly Refined
I need to be brief-its Halloween.
You do not use the thermostat shim--Thermostat spacer - 900-234-160-00.... unless you get a WP from Zims that has a 7mm gap from the WP thermostat shelf to the "C"clip. If you do have the 7mm gap, then you use the thick 4mm thermostat seal that goes around the thermostat and the thermostat shim spacer. If the Zims WP comes with the 4.5 mm gap you do not use the shim, only the 2.5mm thermostat seal. ![]() Another view ![]() You can either order all the parts and have spares or cross your fingers that the pump you get will be the one with 4.5mm gap which is usually the case. Tomorrow... J_AZ
1988 924S, 85,750K ..+ 1987 924S, 154K DD (+15K est. bad odo) |
Converted 944 Guy
Gotcha. I'll order the thermostat spacer just in case. Would hate to get to that point and need one...
I'm also doing the oil cooler seal kit. Should I do this prior to the timing/wp/foes, run the car to make sure I have oil pressure, then do the front end work? Might make it easier to diagnose issues later on, but would require draining the coolant twice. Really appreciate everyone's help. I'm sure I'll have more questions as I get into the project. |
In an earlier post I asked if you had the original 3 piece OPRV or the upgraded 1 piece?
If you are fortunate to have the upgraded 1 piece OPRV you will need new "O" ring seals. ![]() J_AZ
You need a spare camshaft bolt as they frequently need to be drilled out.
Pelican has them. 999-510-022-08-M260 |
Toofah King Bad
Also replace tensioner stud with Porsche part.
» 1987 924S Turbo - Got Boost? « "DETERMINATION. Sometimes cars test us to make sure we're worthy. Fix it." - alfadoc |
Back from Beyond
Do the oil cooler seals while the front is torn down - more room. As mentioned, don't reuse the cam bolt, get a new one. It's a stretch bolt and has to be replaced.
Don't pull the front BS seals. Knock 'em out from behind after you take the noses off. That way you won't scratch up the seal seats. |
Converted 944 Guy
Converted 944 Guy
Be careful with the crankshaft seal, there are 2 different sizes. My copy of the PET calls out the wrong one for my early 85.
The one in the Pelican Reseal Kits section (999-113-268-40-M17) is for 83-84 ONLY it is larger diameter (57 mm?). This one is called out in my PET. The one I needed was in the Oil Circulation section (999-113-331-40-M104) it has a smaller diameter (52 mm). This one actually fits in my car. My engine is untouched so I am not sure when the different oil pump housings were phased in. Also this tool made pulling the crank seal a non-issue: Lisle 58430 Shaft Type Seal Puller : Amazon.com : Automotive Good luck! I just went through all of this so feel free to ask any questions and I will tell you how I stumbled through it! Nate |
Info:
should I replace teh tensioner stud? - Rennlist Discussion Forums Clarks Info--read the footnotes as well. http://www.clarks-garage.com/pdf-manual/eng-04.pdf Start at the dealer? GL J_AZ
Converted 944 Guy
Converted 944 Guy
999.701.602.40 x1 Cam O-ring 999.113.349.40 x1 Cam Shaft Seal 944.105.321.00 x3 Mylar Seal 999.113.282.40 x2 Upper Balance Seal 999.113.281.40 x2 Lower Balance Seal 999.701.652.40 x2 Balance Shaft O-Ring 999.113.331.40 x1 Crank Seal '84- 999.113.268.40 x1 Crank Seal '-84 999.707.283.40 x1 Crank O-Ring 928.105.184.00 x1 Cam Housing O-Ring 999.510.022.08 x1 Cam Bolt 928.105.139.02 x3 Seal Race N.012.708.2 x2 Balance Shaft Woodruff Key 900.082.085.02 x1 Crank Bolt 944.107.161.01 x1 Oil Pump Drive Gear/Sleeve 900.117.036.00 x1 Crank Woodruff Key This one contains both part #s for the seal you mentioned. I'll use the appropriate one. |
