Mike_944's Avatar
Failed smog at idle...(UPDATED...PASSED)
I went to get the car smogged and it passed at 2500 rpms but was running too rich at idle.
Since then I replaced:
-spark plugs
-air filter
-coolant temp sensor
I want it to pass next time so I'm wondering what else I should replace.
2002 E46 BMW ///M3 (Daily)
1987 Porsche 944S (Project)
1985.5 Porsche 944 (Sold)
Old 11-02-2013, 03:06 PM
Proprietoristicly Refined
John_AZ's Avatar
O2 sensor, new cat, move to AZ ??
A few CA "failed emissions" posts may help.
My car needs major CA smog help - Rennlist Discussion Forums
New Cat Options to pass CA emissions?
Failed CA smog... - Rennlist Discussion Forums
Failed CA smog--high CO/HC - Rennlist Discussion Forums
NO problem (emissions fail)
..just a few of many.
You might see a pattern.
Sorry, not much help.
GL
J_AZ
1988 924S, 85,750K ..+ 1987 924S, 154K DD (+15K est. bad odo)
Old 11-02-2013, 03:37 PM
Custom User Title
mikepellegrini's Avatar
More than anything, the new air filter is likely to help.
You might dump in a can of octane raiser stuff next time. That supposedly makes it burn cleaner. Also make sure it's well warmed up (20-30 minutes of freeway driving immediately before testing).
I always red-line it in 2nd and 3rd a couple times as well, to clean all the crap out. I don't know if it actually helps, but still it's a lot of fun...
83 944 NA - Black on black
86 951 - Red - SOLD 7/21
16 Ford Expedition
He who hesitates is lost.
Old 11-02-2013, 03:38 PM
TrailRider's Avatar
Post up your numbers / results as they could mean different things.
Still have the stock cat?
'87 944 Turbo
Old 11-02-2013, 04:33 PM
AFM #725
Gawernator's Avatar
CA sucks huh
Watchdog Armory Racing AFM #725 Thanks to my 2017 Sponsors: JPH Suspension | AXO | Armour Bodies | BELL Helmets | Braven | EVLUTION Nutrition | Forcefield Armor | FunTrackDayz | Galfer | Motion Pro | MOTUL | Matrix Racing Concepts | ODI Grips | OGIO | Shorai Inc. | SPEEDMOB | Vortex | Woodcraft | Wicked Audio
http://www.gawerracing.com
Old 11-02-2013, 06:38 PM
Mike_944's Avatar
I also replaced the AOS seals and some various hoses under the intake.
Old 11-03-2013, 08:54 PM
Mike_944's Avatar
And yes I believe it's still the stock cat
Old 11-03-2013, 08:56 PM
Mike_944's Avatar
What is the deal on this ethanol thing?
Old 11-03-2013, 09:17 PM
Mike_944's Avatar
bumpppppp
Old 11-04-2013, 03:22 PM
Custom User Title
It burns a lot cleaner. So the higher the ratio of ethanol to gas, the less emissions.
16 Ford Expedition
Old 11-04-2013, 07:52 PM
944tothefloor's Avatar
Looks like they failed you on the fuel cap integrity test?
Old 11-04-2013, 10:34 PM
AFM #725
Gawernator's Avatar
Do you have an aftermarket cap? Get an OEM one.. you failed both tests pretty badly lol. Cat could be suspect
Old 11-05-2013, 02:05 PM
TrailRider's Avatar
I passed a month or so ago but failed the first time on HC. Here is what I did to pass (and barely pass...).
1st Test - HC Max-132 Meas-164
Swapped in stock chips (in place of Weltmeister DME KLR chips), replaced O2 Sensor, drove around for 20 minutes before test and let the car idle while waiting for test.
2nd Test - HC Max-132 Meas-132
Just passed... barely!
Spoke to the smog tech at length who believes to get any better results on HC will most likely mean a new Cat for my car.
So, my advice to you is to swap the O2 sensor and/or new Catalytic Converter.
'87 944 Turbo
Old 11-05-2013, 03:00 PM
Mike_944's Avatar
Yea the fuel cap was OEM but didn't pass. I bought another one from pelican.
The HC wasn't too far off so I'm hoping it will pass with all the stuff I changed and the help of some denatured alcohol.
Anyone have any good links for cheap cats/02 sensors in case things don't go as planned?
Old 11-05-2013, 07:45 PM
AFM #725
Gawernator's Avatar
I got the universal heated Bosch O2 for like $40 off eBay...
A cat is going to be at least a few hundred dollars plus installation
Old 11-05-2013, 09:46 PM
A new cat can really hide a lot.
Old 11-05-2013, 11:32 PM
Mike_944's Avatar
I don't know what did it. All the parts I changed or the gallon of denatured alcohol I put in my gas tank but she passed!!!
Old 11-07-2013, 10:01 PM
Congrats, when I lived in CA it seemed I was always on the edge of my seat when it was time for smog testing.
1981 924 Turbo
1987 N/A Auto
Black w/Can-Can Red Interior
Old 11-08-2013, 01:41 AM
TrailRider's Avatar
Wow... and passed very easily. Can you list the items you changed for documentation purposes? Also where did you get the alcohol? And did you add that to a full tank of gas or less?
'87 944 Turbo
Old 11-08-2013, 06:36 AM
Mike_944's Avatar
I listed the items earlier in this post. They were all pretty shot. The coolant temp sensor was soo corroded that it snapped in half when i was removing it.
As far as the denatured alcohol...
-Run gas tank down to where the gas light comes on
-Pour in a gallon of denatured alcohol (bought it from home depot $15)
-Drive it hard for about 15 mins or so to mix the denatured alcohol with the other gas
-If it idles weird, add a little more 87 octane gas till its back to normal
-Time it so you can just drive straight into the shop and start the test
Old 11-08-2013, 01:46 PM
