Carroll Laird's Avatar
A/C Help
My son has just moved to the Pensacola, FL area and has discovered his A/C system is low on freon . Good ole Florida sun and humidity has a way of showing up those weak spots. It has a slow leak that requires refilling about every 3 years (probably the compressor shaft seal but the leak is too slow to find). Can anyone recommend a good shop for A/C work in that area? He also needs a shop for normal maintenance items (belts, brakes, etc.) . He has an 85/1 NA. Thanks in advance for the help!
Carroll
'89 S2
Old 09-03-2002, 08:03 AM
Send a message via Yahoo to Cebu
If the system has been converted to R-134a, ther is stop leak available.
Old 09-04-2002, 04:07 PM
