Here are some pics of front bumper test fit, will be installing it tomorrow.
Florida: working on your car year round wearing just a t-shirt, shorts & flip flops
Can I PM anyone to pay them for pages 15-101 and 102 out of the Engine 1A Workshop Manual?
PHillary - I have sent you an email through the forum.
1981 924 Turbo 1987 N/A Auto Black w/Can-Can Red Interior |
Got some pics of the final install , not perfect but I'm not perfect.
Next weekend the spoiler!
Andrew Gawers' Dad
In 1a (16valves) 15-101 is "tools for adjusting camshaft settings (16-valve engines). Page 15-102 is "checking and adjusting camshaft settings". I took a pic, I'll post em tomorrow.
Andrew Gawers' Dad
There it is. Thanks Jackson.
Thanks Jrboulder, you are the man!
Well then "CHICKS", I owe you a big thank you too. So here it is: Thaaank You!
Andrew Gawers' Dad
No problem. Good luck!
As a precaution, before you start to align the cams be sure to rotate the crank approx 45 degrees to ensure there will be no valve to piston contact. Once you are finished installing the cam chain and have the cams aligned, turn the crank back to TDC, put the crank lock on to hold at TDC and install your timing belt.
Thanks, Will do.
Here's some more photos....
![]() ![]() ![]() ![]() Decided to play it safe and take it mechanic, they have a good Rep and willing to help me put all the pieces back together. |
At least now you have the manual pages to provide to the mechanic so he has something to go by, hopefully he will be able to complete the job in a timely manner!!
Redline Racer
Oil cooler seals are an exercise in frustration with the exhaust headers in place, but so is removing Y-pipe bolts welded to the headers with rust.
At least on the 8V heads, the exhaust valve guides are pretty worn after 150K. Depending on the mileage of the head, it may or may not be a big deal to leave them be. The smaller valves may extend the service life of the guides over the 8V head. Worn guides will accelerate wear on the valve seats leading to lower compression and additional work down the road. I would say at minimum, the valves should be lapped in and valve stem seals replaced. Pretty easy to do if you've already come all this way. Now then there's hand porting the head and intake while you wait for machine work to finish up, but that's another story...
1987 silver 924S made it to 225k mi! Sent to the big garage in the sky Last edited by HondaDustR; 03-03-2014 at 05:16 PM.. |
Added my Momo wheel and Rennline pedal set today. Wanted to get it ready for the shop tomorrow.
