Banned
idle stablizer?
ok, fired her up for the first time this spring.
she does run, but the idle will hunt really badly. like it surges up to about 1800-1900, and then it almost dies, but catches itself at about 900, and then surges again. idle stabilizer shot? i don't think i have any vacuum leaks, ive looked everywhere except under the intake manifold. |
unplug the idle valve and see if it stops...
Banned
nope, figured it out.
the line from the intake manifold to the idle stablizer ... the plug bit pulled out of the intake. threw some locktight on there, press fit it back in, and she runs awesome now! new problem ... while remounting the speed and reference sensor bracket to the intake manifold, i cracked the plug on the sensor side. i pulled all the broken plug out of the harness side, and shoved the three leads into it, and it works. but obviously not a long term solution. have to come up with a better attachment method, or change out the sensor. Last edited by cockerpunk; 02-19-2014 at 03:56 PM.. |
what happens if it stops when unplugged. Im experiencing the same issue
replace the ISV
Stefan Portland, OR 1979 Porsche 924 Carrera GTS (clone-ish) 1988 Porsche 944 Turbo S (Silver Rose) |
Banned
read the thread guys, got it running ...
I know. I was replying to campbelljj's question.
Proprietoristicly Refined
1988 924S, 85,750K ..+ 1987 924S, 154K DD (+15K est. bad odo) |
Andrew Gawers' Dad
It's spring time in MN?
944 addict
I had a broken connector (both sides) of one of the ref sensors. I bought a new female connector on ebay and soldered it into the cable. Replaced the ref sensor with new one. All works fine now.
3 944's, 2 Boxsters and one Caman S, and now one 951 turbo. Really miss the Cayman. Some people try to turn back their "odometers." Not me. I want people to know 'why' I look this way. I've traveled a long way and some of the roads weren't paved. |
SPD
Gordon, I may still have a couple sensors sitting around you can have. I'll have to look in my garage and see if they're still there, but I don't think I tossed them.
Edit: looks like I must have sent them along with the harness a while ago. Sorry for the false alarm.
1984 944 "Elka" Ford 5.0 Last edited by haroldina; 02-20-2014 at 04:08 PM.. |
Banned
no, my spyder spun a rod bearing and is getting a 2zz ... i need something to run around in in the mean time.
haters gonna hate, cars are made for driving. ![]() thanks harold, but i ordered up a replacement plug, and just electrical tapping them together has me running right now. |
