Question Tool 9244 doesn't fit?
I've been working on the belts on the car. I actually decided to buy the tensioning tool and the adjusting wrench, 9244. So anyway, I'm working along, balance shaft belt comes off fine using the 9244 then I get to the timing belt and the tool doesn't fit. The factory workshop manual says 9244 is to be used for adjusting both belts. What gives?
Old 09-09-2002, 03:18 PM
That tool is for the older 24mm adjusters, years ago they changed to 27mm, you need the newer tool.
From November 2012; Precision Porsche Specialist
Sussex UK, +44 (0)1825-721-205
2001-2012 Gerber Motorsport Inc. 206-352-6911
07.15.06 1996 Ducati 900SP. Suprisingly enough, it's red
08.16.09 1999 Kawasaki ZRX1100. Green.
Old 09-09-2002, 04:28 PM
So the next question is where to get the newer tool? The tool I got here at pelican is the older and I don't see a different one.
Old 09-09-2002, 04:46 PM
We use a thin wrench and just bend it to fit. Try a European tool distributor (Hazet, Stahlwille etc..)
Old 09-09-2002, 05:06 PM
951carter's Avatar
Yeah, ain't that a *****! I just use a thin adjustable wrench =))
84 944(sold)
85 944
86 951
87 944(sold)
87 951
88 951
Turn up the BOOST!!!
Old 09-09-2002, 10:37 PM
