help engin is knocking!!!!!!!!
well i just did the oil cooler and not i have no oil pressure and the engin is knocking! i not sure if i did mess some thing up but can soem people give me some idea to do to figre out what it is. it also might be the oil pump because the oil presure was jumping once and a wile before i did the oil cooler. mabey i mess up the oil presser valve? if any on can tell me if it is the green yellow or green wire that hook up to the oil sencer and how i can hook it up right i would like it. i have also trided hooking the wire up both ways. PLZ HELP MY BABY! thanx
Nipzz
85 1/2 944 Project car + daily driver
\_/
Old 09-09-2002, 05:25 PM
You know what? We went through all this about not working on the car without the correct information and equipment and you did and now = one junk 944.......................
You have NO OIL PRESSURE do not run the engine! Try putting another 3 quarts of oil in it and see if you get oil pressure when cranking, then drain it out and set the level.
Go to shop that knows about 944s before you do any more damage.
Jeeeezzz some people!
From November 2012; Precision Porsche Specialist
Sussex UK, +44 (0)1825-721-205
2001-2012 Gerber Motorsport Inc. 206-352-6911
07.15.06 1996 Ducati 900SP. Suprisingly enough, it's red
08.16.09 1999 Kawasaki ZRX1100. Green.
Old 09-09-2002, 05:33 PM
i did read all about it and i tryed to get the tool and the porsche dealer could not get the tool. also i talk to a porsche mechanic about how it do the oil cooler and did his steps. and besides that i also call other porsche shops to try to get the tool. none had it or could get it. i dont mean to be mean but im piss off my car does not work and i miss it!
\_/
Old 09-09-2002, 07:22 PM
AFJuvat's Avatar
WHY???!!!
Nipzz,
You were provided with all of the information you needed - you were sent the manuals, and then provided a link to all of the updates a few days ago. Did you even bother checking that address I gave you - it has all of the updates since the manuals were published. Further, you were warned by one professional mechanic (Britwrench) about stopping what you were doing and getting professional help before you destroyed your engine.
Your oil cooler is not installed properly - coolant spewing out your oil filter mount was the first indication - at that point your crankcase is contaminated with water - those IRON bearings rust and you must clean it out quickly - this post should have been your FIRST warning:
Oil cooler seals
Obviously, either your seals are off, you didn't install the pressure relief valve properly, or you don't have the pressure sender installed correctly - which by the way has a non-removable crush washer - are you sure it is sealing properly?
Assuming you corrected the coolant spewing through the oil system problem, did you take active steps to ensure that you maintained oil pressure - there are countless posts on this subject - all you had to do was click "search".
I refer you to repair groups 17 and 19 in volume 1 of the workshop manuals (Volume 1x, NOT Volume 1Ax) those sections deal with the lubrication and cooling systems - they provide exploded parts diagrams, instructions of what needs to be replaced and how things must be aligned, and how to torque them properly.
Unfortunately, unless you are very lucky, you will probably have to pay close attention to Volume 1, Repair Group 13 (Crankcase/piston/bearing removal/replacment) & Repair group 17, page 17 "Cleaning the entire engine oil system after engine (bearing) failure.
**shaking head in dismay**
AFJuvat
Es geht nicht darum wie schnell man faehrt, sondern wie gut man schnell fahren kann.
Ihr Brunnen der nutzlosen Porsche Information
Old 09-09-2002, 07:27 PM
overkill's Avatar
Send a message via AIM to overkill
Dude,... it's "tried", he he he
{1987}944S - (SOLD).
Old 09-10-2002, 02:07 AM
