944 drive train problem
My 1986 944 with 5 speed has a problem after my teenage son used it for one night on the town. When you let off gas to coast in gear it starts to buck and jump, which it did not do before he used the car. I think that there is a clacking noise somewhere behind the clutch but not all of the time. What do you think he did?
Old 09-23-2002, 03:50 PM
Your son needs to buy you a new clutch...............
Probably the rubber center has broken up in the clutch. If the clutch has done over 70k miles it's not all his fault, it's just worn out..however, you don't have to tell him that.
From November 2012; Precision Porsche Specialist
Sussex UK, +44 (0)1825-721-205
2001-2012 Gerber Motorsport Inc. 206-352-6911
07.15.06 1996 Ducati 900SP. Suprisingly enough, it's red
08.16.09 1999 Kawasaki ZRX1100. Green.
Old 09-23-2002, 05:22 PM
SoCal Driver's Avatar
If my dad had ever know half the stuff I did to his 64 Corvair van I wouldn't be writing this right now.
I concure: clutch. From rice racing. We used to call it drag racing. Get the spring center one when you fix it.
After I had to replace one axle, busted the U-joint, and the speedo cable the broken axle took out; I backed off doing the rough stuff.
Hugh - So Cal 83 944 Driver Person
NOT a 'real' Porsche -- Its Better!!!!
When was the last time you changed your timing and balance belts and/or cam chain and tensioner?
New Users please add your car's year and model to your signature line!
Never break more than you fix!
Old 09-23-2002, 06:13 PM
AFJuvat's Avatar
In truth, it was probably on its way out anyway = though I would venture to guess your son probably helped it meet its maker.
You could squeeze this for months of lawn/chores/cleaning and waxing the car.
AFJuvat
Es geht nicht darum wie schnell man faehrt, sondern wie gut man schnell fahren kann.
Ihr Brunnen der nutzlosen Porsche Information
Old 09-23-2002, 07:40 PM
dasMafia's Avatar
Send a message via Yahoo to dasMafia
you guys are great.... I'm totally going to fit in around here!!!!
I'm glad you guys weren't friends with my dad... I'd STILL be grounded!
- I pray every day that God gives me the strength to endure this time of grief, of mourning, and of sorrow. That I might persevere in this time of doubt, and that one day, one day soon, like the Phoenix rises from the ashes, the Roadster Will Rise Again!
Old 09-23-2002, 08:13 PM
