This is typically a sign of intake-leaks and/or misadjusted throttle-plate, idle-screw and idle-stabilizer. Follow the manual's procedure for disabling the idle-stabilizer and setting the idle-screw. With the idle-stabilizer disabled, setting correct idle-speed on a warmed-up car will have it not contribute any extra air to idle-speed. No catch-up game with overshooting and undershooting.
You may also have a sticking ICV. A little carb or TB or MAF cleaner down the ICV hose may free it.
944 addict
3 944's, 2 Boxsters and one Caman S, and now one 951 turbo. Really miss the Cayman. Some people try to turn back their "odometers." Not me. I want people to know 'why' I look this way. I've traveled a long way and some of the roads weren't paved. |
944 addict
O2-sensor coax-shielding goes to pin# 23 (also shared with shielding from speed-sensor). There should be no continuity between these two pins. Have an assistant wiggle the O2-sensor wires in the engine-compartment while you watch the voltmeter. Also disconnect and connect the O2-sensor, shouldn't have any continuity. While there, you'll want to open up the wiring-connector and solder a wire to the back of the #24 terminal-pin to extract an O2-sensor signal for monitoring. That's the best location to get it. Many people run a wire out to the engine-compartment and hook it up to the O2-sensor connector just before the it connects to the shielded harness wire. But then you've got an unshielded cable running parallel to the shielded cable and you won't be seeing the exact signal that the DME's getting. With a fully-warmed up engine, you should see the O2-sensor voltage flip back and forth across 0.5v about 4-5x per second: 0.8->0.5v->0.2->0.5v->0.8 etc. It should be symmetric on both sides of 0.5v. If it's leaning heavier towards one side or the other, then you may have a problem with O2-sensor and/or wiring. Use pin#28 for sensor-signal ground (not power ground or body). |
2. And check the throttle-butterfly axle for leaks, that can actually be significant enough to mess with idle-speed and the ISV. There's a write-up somewhere along with list of O-ring parts needed to re-seal. 3. check the O-ring under the throttle-bypass screw (idle-speed adjustment). If O-ring isn't fully sealing, that too can be a source of leaks. |
944 addict
I'm not sure what you're referring to on the butterfly positioning.
The stumbling issue goes away when you disconnect the O2-sensor. Assuming that the replacement O2-sensor is working properly, then we have to assume that something is wrong with the O2-sensor wiring. If you've verified that the O2-sensor signal-wire is not shorted to the shielding braid, then we should test the O2-sensor signal at the O2-sensor plug itself. Then test it again at the DME terminals to make sure it's the same signal. If this is a 944na, we should verify that the full-throttle switch on TPS is working and that terminal activates properly at the DME terminal. If a 951, should verify that full-throttle signal is coming from KLR. Last edited by DannoXYZ; 07-28-2014 at 10:40 AM.. |
