Toran's Avatar
How to get the CV Boot clip on tight?
Hello All,
Thanks to this forum I was able to replace my worn CV Joints.
After getting everything back together I did an inspection and noticed my CV boot clip isn't as tight as it should be.
Can someone please share this technique?
Is a tightening tool used?
Good source for newer and improved cv boot clips?
T.I.A.
86 944na Alive and Rollin
Old 08-07-2014, 08:20 AM
Yep, there's a tool for that...
Try googling "CV JOINT BOOT CLIP TOOL"
Good luck, George Beuselinck
Old 08-07-2014, 08:45 AM
Bradical's Avatar
Can I borrow it when you are done with it?
Old 08-07-2014, 10:19 AM
Andrew Gawers' Dad
CHICKS's Avatar
Here's what I use: http://www.amazon.com/Lisle-30800-Boot-Clamp-Pliers/dp/B0002SREPY/ref=sr_1_2?ie=UTF8&qid=1407432967&sr=8-2&keywords=cv+clamp+tool
Free for loan in Colorado.
Old 08-07-2014, 10:35 AM
You could check AutoZone. They loan out a lot of tools for free.
Old 08-07-2014, 09:32 PM
Toran's Avatar
Thank you Everyone!
I was thinking my piano fingers just aren't strong enough to squeeze this tight enough.
Now I see that even the big manly man hands of this forum use a tool for this!
Sure Bradical, I'll pass it on to you
Thanks again!
Old 08-08-2014, 05:29 AM
