Shift Points...
Another newbie question...
What are your shift points for smoothest acceleration ? I am noticing in my 85.5 that I have to shift at about 4000 RPM for a smooth acceleration and transition between gears. I do not have the shift indicator on my 944 or it doesn't work...LOL Is this typical ? |
944 addict
I don't change gears at anything below 3000 rpm. Small displacement engines like these develop their HP at higher RPM than big displacement cars.
3 944's, 2 Boxsters and one Caman S, and now one 951 turbo. Really miss the Cayman. Some people try to turn back their "odometers." Not me. I want people to know 'why' I look this way. I've traveled a long way and some of the roads weren't paved. |
It it's a Canadian car, there is no shift light.
Over 3, I agree.
1986 944 NA Sapphire Metallic http://944porsche.blogspot.ca/ |
plays with toy cars
between 3-3500 for normal daily driving, 3500-4000 for "I'm in a good mood" driving, often times higher when having fun on the way home from work/class. I try to keep things under 5500 except for special occasions, just to keep wear down as much as I can. It's not like the 8V really prospers in a huge way after that point.
1983 944 - modded everything http://forums.pelicanparts.com/dto_garage.php?do=viewvehicle&vehicle_id=28317 '86 951 - under construction http://forums.pelicanparts.com/dto_garage.php?do=viewvehicle&vehicle_id=28374 |
for slow around town driving with the MAF you can easily get around shifting in the 2000s, barely have to touch the clutch to get the next gear and the spacing is close enough that it reengages smoothly. with the afm its a little higher than that, the MAF gives you a lot more torque.
then again, you can shift just as butter-smooth at 6000rpm if you're well-dialed into your car. if im in a drive-fast mood ill take it to 6500 in 1st/2nd gears, 3rd gear would put me over 100 at that rpm so thats a rarer occurance. |
Shifting smoothness isn't so much about RPMs as it is about coordinating the clutch and throttle just right.
Such as letting off the gas (but not all the way) and stepping in the clutch at the right time so as to not jerk the car. Then you'll want to shift and match RPMs to the road-speed so that when you let out the clutch, the RPMs don't change and jerk the car. In fact, if you do the throttle foot just right with matching RPMs, you don't even have to use the clutch at all! |
Ornery Bastard
Technically true, but in practice that should never be done with a synchromesh transmission. It's really, really, really hard on the synchros.
--------- Silver 1998 Volvo S70 T5 <- Daily (Anja) Guards Red 1986 951 <- Seattle car (Gretchen) White 1976 914 2.0 F.I. <- Prodigal car, traded away then brought back again (Lorelei) |
Here's what Porsche had to say about it in the manual...
Early Pre 85.5 ![]() Late 1985.5 ![]()
Current: 87 944S Black/Black, 89 944 Turbo S ANDIAL White/Burgundy, 78 924 Black/Black, 17 Cayenne S, 03 Turbo X50 Aero instagram @mhariush http://stores.ebay.com/Techniker-Parts/ |
Have 944, will restore
I'm generally between 3000 and 3500 rpm, depending on traffic. I use the CASIS light occasionally but if you shift as soon as it comes on, the engine tends to bog a bit.
85.2 944 Guards Red M456 5spd 85 RX-7 Ocean Blue 5spd /80 RX-7 LS 5spd 84 RX-7 GSL-SE/ 88 RX-7 10th Anniversary 04 RX-8 Brilliant Black 6spd/ 04 RX-8 Nordic Green 6spd 84 Corvette 4+3, 93, 95 Corvette 6spd, 18 Camry SE |
Thread Tools | |
Rate This Thread | |
