Automatic temperature control
Hi,
My 1987 951 is equipped with the automatic climate control system.
Now, if I understand the instruction manual correct, the systems should heat or cool the interior temperature to the temperature that I set on the dial (cool if the A/C button is pushed of course).
Now as far as heating is concerned (up here in Michigan we're already getting to temperatures where a little heat is quite comfy) the heater only blows hot air if I set the dial to its maximum temperature. Any setting lower than this does not have any result as far as getting heat (the A/C has been turned off of course).
When I turn the windshield deforst button, the heater immediately blows hot air, regardless of the position of the temperature knob or A/C switch.
Is this a familiar behaviour? How about temperature setting with the A/C on, in case I want to cool the car's interior to a desired temperature?
Thanks a million?
PT
Old 10-03-2002, 07:07 AM
AFJuvat's Avatar
Ahhh Michigan in winter... I remember it well (I grew up in Sterling Heights) - which is why I now live in Florida.
The defrost button will overide any other setting, blowing hot air at the windows, through the doors, and across the rear hatch (thats what those holes in the back are for)
The temp knob is supposed to control the mix of warm and cool air - it is controled by temperature sensors in the dash. You shouldn't get full blasing heat unless the temp knob is pegged all the way to hot. That said, you should notice a temp difference anywhere across the scale.
If you aren't, either your temp selector knob is bad, or your temp sensors are bad.
Verify that the temp is changing as you move the knob from cool to heat - it should get progressively warmer. The most common failure is temp sensor.
AFJuvat
Es geht nicht darum wie schnell man faehrt, sondern wie gut man schnell fahren kann.
Ihr Brunnen der nutzlosen Porsche Information
Old 10-03-2002, 07:18 AM
Scott R's Avatar
Two things to check:
1. Proper operation of the servo controlled mixing flap. It’s located just above where you right foot sits in the drivers foot well, behind a plastic cover. Remove the plastic cover and turn the car on, move the climate dial to both extremes. That motor should move the mixing door all the way open and all the way closed.
2. There is a climate sensor behind the glove box. This sensor has air drawn over it by a miniature fan; this samples the cabin temp and sends the signal to the climate panel that operates the air flap motor. Sometimes this sensor gets covered in lint or hair and needs to be cleaned before it reads accurately.
Hope this helps.
BTW on another note, even when the system is working tip-top it's not very accurate in my opinion.
2021 Model Y
2005 Cayenne Turbo
2012 Panamera 4S
1980 911 SC
1999 996 Cab
Old 10-03-2002, 07:20 AM
SoCal Driver's Avatar
Geesh! I just move the slider on my 83 a bit!
Hugh - So Cal 83 944 Driver Person
NOT a 'real' Porsche -- Its Better!!!!
When was the last time you changed your timing and balance belts and/or cam chain and tensioner?
New Users please add your car's year and model to your signature line!
Never break more than you fix!
Old 10-03-2002, 09:39 AM
Wow
Thanks for the hint!
Old 10-03-2002, 11:04 AM
Re: Wow
Sometimes I wonder if the greatly improved air handling of the late model 944's is worth all of the gizmos that make it work.
Old 10-03-2002, 11:12 AM
AFJuvat's Avatar
heheeh you should see what it costs to replace the unit - there was MUCH rejoicing when Porsche finally allowed the switches to be sold as individual parts.
AFJuvat
Old 10-03-2002, 11:47 AM
