Book search 2.5L rebuild
Can anyone direct me to a good engine rebuild book for my '85' 944 2.5L? Lots of general rebuild books out there for your brother's small block Chevy :-( I need something specific. Shocked there are none available in the Pelican book store.
Andrew Gawers' Dad
We have: workshop manual, and the tech and specs book.
what do you need to know?
it comes apart like any other engine. the wear specs and torque specs are in the Haynes manual. |
Have the Haynes book, did not seem detailed to me. Concerned with placement of balance shafts and cam belt tension. Also would like to know cam and piston options. Can the head be shaved for more compression? Other performance tricks?
The newest of the noobs!
If you read between the lines, these topics have been covered, a lot! So, 'search' is your tool of choice, per the collective~! I just did an engine out reseal of the entire engine, FOES, etc., all done via Clark's Garage, a few email friends, and searching the Pelican data-base.
1989 944 Turbo 2004 Jeep Wrangler Unlimited - Built! 1985 Saurer 6dm overland Swiss military truck/camper |
Head can be shaved for more compression but it doesn't do a whole lot for you. IIRC the max you can shave is about 0.060". The wear spec is in the Haynes book. You measure the head thickness with a caliper between the head surface and the little cast pad on the front corner of the head by the coolant gooseneck.
Pistons are all the same from 82-87 NA in USA, 88 they were higher compression ratio bumping power from ~143 to ~152. Those pistons are prized by the racer guys so they come at a price. Camshafts can be bought from WebCam, Elgin, and John Milledge in the USA (if you can get a hold of John Milledge, he isn't easy to reach!). They typically give up some of the low-end performance in exchange for 5-15HP at the high end, but no one seems to have any dyno sheets to share to prove the gains, although Milledge insists he has tested his. Balance shaft placement is actually pretty easy - the gears on the ends can go on two ways but you align them with two steps - there is a notch on the back lip of each of the gears that has a TDC mark that lines up with a notch on the rear belt cover. On the front face of the gear is stamped a "0" which should be visible at about the 11 o'clock position on the upper balance shaft and about 5:30 on the lower balance shaft when both gears are set to TDC marks. The easy way to set belt tension is as follows: grab the longest span of the belt (between the crank gear and the cam gear on the timing belt, without the idler installed; between the upper shaft and tensioner on the balance shafts, without the idler installed) between your thumb and forefinger and twist the belt. The timing belt should be just tight enough that you can turn the belt 90 degrees between your finger/thumb and no more. The balance belt is looser, you should be able to twist it about 180 degrees around with your finger/thumb. The belt job is really a lot easier than some people make it out to be. Take your time and note all the little steps as you do it, but once you've done it a few times you can just go off memory. I have done so many cars that I can take my time on an NA and have a running car with new belts in about 2 hours. Honestly...the Haynes book has almost every spec and instruction you could need for rebuilding the engine and maintaining the car. Only a few procedures require other information and you are well-served there by Clarks-Garage and the forums. It's really the best, most-useful $15 you could spend to learn about the car. As far as performance modifications, I can tell you the following as the ultimate, best bang-for-your-buck mods to make your car way more fun to drive. Some people will tell you to strip weight but I would advise against removing carpet/sound deadening unless the car is just a toy for weekend street driving or track days. You will hate the car with no sound deadening if you drive it often/daily. 0) make sure the engine is well-maintained in good condition, runs well, etc before modding anything. 1) Weltmeister/other brand throttle body cam (available here on Pelican, PN# PEL-PP-905837). This changes the way the throttle opens relative to gas pedal position. The stock Porsche throttle cam is a piece of s**t and makes the car feel ridiculously slow at anything under full throttle. the Weltmeister cam truly changes the character of the car and makes it a lot more fun/easier to drive. They are about $28 new, or you can take your stock throttle cam and cut off the long leg to make it approximately circular in shape for the same effect. 2) MAF conversion. I like Rogue-Tuning's NA-tune MAF kit (roguetuning.com). It truly transforms the car. You gain a little bit of power at the peak end (5-6 whp) but WAY MORE power/torque everywhere else in the RPM range. The car runs smoother at idle and has way more "pull" at all RPMs. I dyno'd my car before/after the MAF conversion and gained from 10-14 wheel ftlbs from 2000RPM til about 4000. You can cruise along at 2000rpm effortlessly with the MAF whereas the AFM setup requires a lot more RPM/throttle. The Rogue MAF conversion is $500 or so and worth every single penny. 3) Only944 shifter setup (Only944.com). The Shifter lever update with the bolt and thrust bearings makes the shifter feel a lot tighter in your hands versus the sloppy worn out stock item. It can be improved even more with his short-shifter setup and solid-link bar so there is almost zero play in the shifter, just nice, smooth, perfect gear placements. The shift lever/short shifter setup is around $150, maybe less, I dont remember off hand. Last edited by v2rocket_aka944; 09-12-2014 at 07:36 AM.. |
+1 on the advices V2 rocket, may I add some tweaking to the suspension(shocks-springs-wheels & tire ect ect )which will help your 944 performance.There is plenty of useful infos on this forum on how to go about it without breaking your piggy bank.Have fun Ron_944
If you want to get really into it
Jrboulder: I will get the book.
v2rocket: perfect! Thanks! All: Thanks. |
Andrew Gawers' Dad
That book is like $300 FYI.
You can download it free at this link, I haven't tried it. I deleted the link because Norton blocked it, it isn't a safe site.
Clifton Last edited by flash75; 09-14-2014 at 05:25 AM.. |
Content deleted.
Clifton Last edited by flash75; 09-14-2014 at 05:26 AM.. Reason: Norton blocked the download, it's unsafe |
Do a search in Google...there is a site that sells a digital version for $45...site is the Abrasive Engineering site
John |
Thread Tools | |
Rate This Thread | |
