1995-968
Troubleshooting 968 Inoperative Speedometer/Odometer
I have been T/S this for some time. Neither Speedo nor Odo works, I have already checked gears and they are fine so now believe that there is a problem in the signal path. Problem is I cannot find much info on where the pickup sensor for the speedometer is located, lots of info for 944s but not for the 968s. Anybody have any experience with this?
Old 10-07-2014, 11:07 AM
flash968's Avatar
i always seem to forget this one, but i'm pretty sure it's at the front right wheel/hub.
Old 10-07-2014, 12:19 PM
It's one of the ABS sensors, there is a signal line from the ABS brain to the cluster, you could check it for a signal.
1987 928S4
1992 968 cabrio
2009 957 Cayenne GTS
Old 10-07-2014, 02:32 PM
Tags
968 speedometer t/s
