NEED HELP FAST! Can't find sensor bracket.
Hey guys/gals. I know I'm a noob here as well as a noob to owning a Porsche. This is my first and it's an 83 944 N/A. I got it and the reference sensor was bad. i tried to pull the sensor out and broke the bracket that retains the reference/speed sensors. I cannot seem to find a bracket that matches this one. Can anyone help me find where I can get the correct bracket? The part number on the bracket is 944, 101 3212R. Please help as this is going to be my DD as soon as I get it fixed and I have 2 brand new OEM sensors with no home. Also I was thinking of just welding this one back together (The bottom screw hole is what broke) however I tried everything I could think of to remove these two sensors and they will not budge. I'm guessing they will have to be drilled out. Any and all help would be greatly appreciated.
Very Respectfully, Justin |
1983 944 N/A
There's one on ebay item#111481303786
"To my family, the 944 is more than a new car. It is a new and true Porsche. At Porsche, excellence is expected." Dr. F. Porsche Stuttgart |
Thank you but that is not the correct bracket. I searched ebay and cannot find one that is the same part number/design. The one I need is 944, 1013212R I just can't seem to find the part number anywhere. There has to be one somewhere.
Andrew Gawers' Dad
Pic?
West Central Ohio 45380
I have them see my tag or pm me
www.plyhammersparts.com |
plyhammer i've sent you a PM
Toofah King Bad
You likely have an early bracket with a diagnostic sensor on it (3rd sensor). This is a vestigial piece, and may be replaced with any 2.5 sensor bracket from the scrap yard.
» 1987 924S Turbo - Got Boost? « "DETERMINATION. Sometimes cars test us to make sure we're worthy. Fix it." - alfadoc |
The bracket I have has only 2 sensor holes. It does not have the 3rd sensor spot i've seen on some of these other brackets.
one of gods prototypes
The 3rd hole is for a dealer timing light atatchment and isn't needed. ..... The sensor in the 3rd hole closest to the drivers side is that sensor you don't need.....
Have 944, will restore
Were you able to locate one?
85.2 944 Guards Red M456 5spd 85 RX-7 Ocean Blue 5spd /80 RX-7 LS 5spd 84 RX-7 GSL-SE/ 88 RX-7 10th Anniversary 04 RX-8 Brilliant Black 6spd/ 04 RX-8 Nordic Green 6spd 84 Corvette 4+3, 93, 95 Corvette 6spd, 18 Camry SE |
Plyhammer is who I'd buy it from! Always the right part with the best prices. I should get frequent buyer points buy now Mark! ...Just sayin'
'87 951 Nile Green, '86 951 Black, '86 951 Sapphire Metallic, '87 944 Nautit Blue, '84 944 Black (sunroof delete) "Track Beast!," '87 944 Black (LSD, Konis) (wife's track car) |
Thread Tools | |
Rate This Thread | |
