More Boost!
Another TDC question
Doing the belts/wp/roller/front reseal on the 944T and finding my TDC marks not lining up. The camshaft timing looks good, but the lower balance shaft and top balance shaft marks are both off.
I cannot read the bellhousing TDC mark by the reference sensors, too much crap in the way. So from what you see, should I be okay to install the flywheel lock? Picture below. ![]() ![]()
I think you should find that flywheel mark - I know it can be hard to see so once you find it mark it with white paint - it's just a line across the top flywheel surface and blends in - either your balance belt is off a tooth or your timing belt is - no way of knowing which unless you make sure the flywheel is spot on
84 928 S - SOLD 2012 Cayenne S |
Andrew Gawers' Dad
It doesn't matter where the balance shafts are at when setting TDC for the cam belt. Look for the TWO flywheel marks and the cam mark.
More Boost!
Still a no go, I checked the flywheel and found the raised line off by 1inch from the starter/bellhousing notch. What's even stranger is I get significant resistance when trying to rotate the engine over at the crank bolt trying to get TDC.
I must be really messing a something up, I should have been done by now. On a good note, all cooling hoses and clamps are replaced, differential fluid replaced, oil and filter done, spark plugs, cap and rotor replaced, so still a good day, but I want to be driving!!!! /
One apex at a time
This makes me cringe. Best hope it is just a lot of compression and not a valve hitting a piston
More Boost!
I hope not, I just drove the car right before doing all this, belts didn't jump a tooth...I might grab a beer to think it out. Thinking about pulling the spark plugs out to see if it relieves the compression.
Probably your best approach. You need to get that flywheel mark centered within the window and keep the cam mark lined up.
1981 924 Turbo 1987 N/A Auto Black w/Can-Can Red Interior |
You've probably tried, but I usually get best results on seeing the flywheel TDC mark with a high-powered flashlight and one knee on the upper strut mount. It helps to have a helper so you can watch for the mark. Some cars have a cover over the inspection hole, so there's that... Strictly speaking, if you are 100% sure that the alignment is on, you could align the cam pulley mark and stick the flywheel lock in. As long as you put it back together the same way, it should be as fine as it was before you started. I'd probably only do that if I somehow ended up with a flywheel with no mark though.
1987 Guards Red 924S 1986 White Toyota MR2 |
...For what little it's worth, I've never been able to see the alignment mark through the window on mine (a 951) and have always used the bell housing. |
The only trick with this method is ensuring the cam isn't 180° off when cylinder #1 is at TDC. Not tricky at all, really.
1987 Guards Red 924S 1986 White Toyota MR2 Last edited by argiopeweb; 10-14-2014 at 07:28 PM.. |
Also, its certainly the compression thats hanging you up, pull the plugs first. |
More Boost!
--phil |
Toofah King Bad
Object in the hole is a terrible method. Next time you have an engine apart, look how much time the piston spends NEAR the top of the cylinder as you rock the crank back and forth. You could easily be several degrees off doing it this way.
"Too much crap in the way" is a poor excuse not to use the factory timing mark. We've all made it work, just get it done.
» 1987 924S Turbo - Got Boost? « "DETERMINATION. Sometimes cars test us to make sure we're worthy. Fix it." - alfadoc |
More Boost!
I found if you close one eye and hold a flashlight right next to your open eye it is possible to see the mark through the top of the bellhousing.
Toofah King Bad
Awesome. . .just the tone I was going for!
More Boost!
I get it from the wife too, "going to see the mistress?", when I go work on the porsche. I just want to get back into the seat and drive it a bit before the snow flies, otherwise its staying the garage for 6-7 months till spring.
More Boost!
So, ultimate bonehead here. I pulled the plugs tried and still nothing. I stood there staring at the car in disbelief, and while doing that i was looking at the dash and saw the car in gear, enough said. TDC was found easily.
I wish I could say I havent done that before.
Good going, brother! If you havent already, watch Van's video on youtube.
