Quick rev limit question
I was wondering...Does bouncing off the fun limiter, err I mean rev limiter, hurt my car? i have done it several times, once goin' down the quarter at sears point, and It sounds painful. If I just put it in say...2 and held the gas...would all the violence hurt my engine? I have never had a rev limiter before (took my ol' 87 accord to 7200 when line was at 6...but that doesn't count) and am curious. When the tires are spinning...on accident of course...in first gear would the engine bouncing off the limiter be bad? You know...for those quick 2 lane U turns. Lately I have been trying to wear away some pesky flatspots...and It got me thinking...thanks. Also what seems to be a reasonably priced early S. You know...the dependable type. Thanks again.
If you don't live life on the edge, you take up too much space.
Old 10-13-2002, 01:28 AM
Obin Robinson's Avatar
no, the car is built to take it without a problem. it is a violent FEEL to tell you "hey, quit it!". it won't damage anything though unless you drive all day long trying to do 55mph in first gear.
but you're fine. i have the rev limit raised to 7,000rpm in my car and i've hit it. i hit the limiter in every car i've owned and never had a problem.
as long as your car is getting proper lubrication, the belts and hoses are okay, and it's in tune, you're fine.
obin
"Resale value": the phrase most often uttered by people who are afraid to admit they can't afford their car.
Old 10-13-2002, 04:48 AM
Have to agree on that, though by raising the limiter (my 951 has the limit raised as well) you will exceed FACTORY specs. Meaning the engine can have it, but don't do it too much. When hitting the factory limit there's no real problem at all, the engine is designed to run at that rpm, but you shouldn't keep it at the limiter too long though, just touching it now and then in 2nd when between two hard corners is no problem at all.
Old 10-13-2002, 09:28 AM
SoCal Driver's Avatar
When you hit the rev limiter you are on the down side the power range of the engine. You should have shifted just bit earlier.
I do think that the rev limiter could be just a bit softer when you come up on it.
Hugh - So Cal 83 944 Driver Person
NOT a 'real' Porsche -- Its Better!!!!
When was the last time you changed your timing and balance belts and/or cam chain and tensioner?
New Users please add your car's year and model to your signature line!
Never break more than you fix!
Old 10-13-2002, 10:28 AM
Nabeel's Avatar
Send a message via AIM to Nabeel
What exactly is the rev limit for our cars? I've had mine at an indicated 7000rpm a few times and I didn't feel a limiter kicking in....
When I want max acceleration I usuallyshift at 6.5K.
'85.5 944
Kalahari Beige/Brown
5-speed
76K miles
color-matched fuchs
SOLD
Old 10-13-2002, 03:04 PM
todwic's Avatar
Send a message via AIM to todwic Send a message via Yahoo to todwic
The rev limiter tells your DME to open injectors every other time, so it's like running out of gas 3,250 times a min. untill your Dme kicks it back to full time. No harm no foul
Factory limit:6500rpms
*Disclaimer: The person above is actually dumber than he appears.
my web site Torque values maintainance and repairs lots of my rebuild pics weights and measurements
'84 944 auto/ps/ac/cc
'86 951
Providing ignorance one post at a time.
Old 10-13-2002, 03:09 PM
Nabeel's Avatar
Hmmm, that's interesting. Can't a chip raise your rev limit? The PO of my car mentioned that the engine had a chip in it, but the guy did not seem that informed, so I thought maybe it was some BS the guy who owned it before him said. Now I don't know.
'85.5 944
5-speed
76K miles
color-matched fuchs
SOLD
Old 10-13-2002, 03:37 PM
todwic's Avatar
aye, they usually do. From what I've seen, the SOP of chippers is 7,000 rpms, tho 7,500 I've heard of, but I wouldn't go that high. That being the case, I would think that you could do away with the limit altogether, if you didn't like your car very much.
'86 951
Old 10-13-2002, 03:40 PM
What about the coil wire Tod?
Old 10-13-2002, 04:08 PM
todwic's Avatar
You have to remove the coil wire and replace it with an Etch-a-Sketch if you plan to go over 7250rpm's.
'86 951
Old 10-13-2002, 04:14 PM
At least the DME does the rev limiting and not the rotor in the dist cap.
Old 10-13-2002, 04:15 PM
todwic's Avatar
I've had my rotor limit my rev. wouldn't go a lick over 0rpms.
'86 951
Old 10-13-2002, 04:17 PM
I had one too. That is till I put it back in the dist!
todwic's Avatar
So that's where they go. Couldn't see much sense in having it on top of the air filter.
'86 951
Old 10-13-2002, 04:18 PM
Air filter?
Don't need no stinkin' air filter!
Old 10-13-2002, 04:19 PM
todwic's Avatar
Then how do you change the air in your tires? Crimmey you're bazaar!
'86 951
Old 10-13-2002, 04:21 PM
Bazaar?
I though our cars were made in Germany?
Old 10-13-2002, 04:23 PM
todwic's Avatar
where do you come up with this stuff. If they were made in Germany, why is everything written in Lhapish?
'86 951
Old 10-13-2002, 04:24 PM
That's what happens when you eat too much raindeer.
Old 10-13-2002, 04:25 PM
todwic's Avatar
too mu...what? that's like too much beer, or too many dents in my nugget. crazy talk
'86 951
Old 10-13-2002, 04:32 PM
