speed/ref sensor plug = 5 wires ???
I picked up a used 951-in-a-box about a year ago and put it all back together. I've been troubleshooting a random no-start condition. When this occurs, I wiggle the connectors for the speed/ref sensor and it starts right up every time. Figured there's a corroded or loose-wire. I've replaced both harness connectors with new ones and they have proper continuity to the DME.
While doing that, I noticed that one of the plugs on the sensor-side had been replaced, so I pulled off the rubber-boot and found this:
I can match up the shielding-braid, signal and ground-wires to the wiring-diagram and they go to the DME properly. Basic resistance checks on sensors is OK according to procedure on Clark's Garage. Oscilliscope waveforms are over minimum height with no noise, so I think it's this sensor plug that's been replaced. Some questions:
1. What are the two additional smaller wires on the side?
2. Should they be connected to something?
3. Should I clip and wrap the ends? They have wire showing and I suspect they may be shorting against the braid, which may be why I'm getting random no-starts until I wiggle that connector.
Thanks.
Old 11-29-2014, 05:54 AM
yarfk
kfray's Avatar
It appears this shielded 4 conductor cable replaced the original 2 conductor shielded cable which connects to the sensor. The 2 extra wires are not required and should be taped off. Make sure that the wires going to pins 1 & 2 a solid connections. Also make sure that there are no breaks or nicks in the insulation on the wires in pin 1 & 2 that the shield strands might be touching.
I do not know why there would be a 4 conductor shielded cable to the sensor, seems as this is some type of hack, it may be best to replace the sensor.
------Keith------kfray------yarfk-------
87 944 NA stock 116k
06 Honda Ridgeline 83k
10 Vibe 2.4 AWD (Wife's)
Retired My week consist of Saturdays and Sundays
Old 11-29-2014, 06:14 PM
The cable is the original factory wire that goes to the sensor. The other end goes into the plastic part on the sensor just like the other one. Although this cable is about 2" shorter due to plug-replacement.
I checked continuity of those two wires and they don't connect to each other or any of the other wires. Perhaps they're connected to the metal-sleeve of the sensor? Didn't check that as I didn't want to pull out the sensor to test.
Anyway, I've clipped off the exposed ends of those two little wires and taped them up. Also poured silicone into rubber-boot before sliding it back on similar to the harness-side connectors. Hopefully that'll remove the stress-riser where the wires go into the plug. So far, it appears to be working, started up on the 1st crank. But the random no-starts were truly random, sometimes shows up once per day, sometimes once a week.
Thanks for the help!
Old 11-30-2014, 04:00 PM
Porsche 944S Club Sport
guru944's Avatar
Send a message via AIM to guru944
Thumbs up Ungrounded wires unwanted noise and DC offset charges.
Those 2 extra wires are not OEM however if they are not connected to anything, i would recommend also grounding them to the shield. That will prevent them from floating (noise) or building up DC charges like a capacitor and corrupting the timing signals from the sensor(s).
Later...
Guru944
2006 955 Cayenne S Titanium Series - Marine Blue, 1987 Porsche 944S Club Sport.
1987 Buick Turbo-T Lightweight "Great White", +500HP, TA49 Turbo.
http://www.blackbirdmotorsports.com, 944/951/968, 911 and 955/957 Performance Solutions.
Thank you Lord, for your Loving Kindness, Tender Mercy, and Grace. Only You are Faithful.
Old 12-02-2014, 02:45 PM
