idepaal oil for 944 in hot country and ZDDP Q
Dear members
i know i am opening a massive can of the wrigglies here....but what are the recommendations for oil for the non turbo 944?
Synth, semi synth of old mineral GTX?
And is it really important to have ZDDP ?
thanks for your patience.
I'm taking cover now lol
MJ in Beirut
Old 12-31-2014, 08:02 AM
Northern Motorhead
wildcat077's Avatar
While you take cover,you can take two Tylenols and do a search on the topic ... there are tons of different opinions,more than enough to make you dizzy
Cheers
Phil
Cheers
Phil
89 Coupe,Black,95 3.6 engine and the list goes on ...
1983 944 SP2 race car PCA #96
Old 12-31-2014, 09:15 AM
ernie9944's Avatar
Originally Posted by Beirut944 View Post
Dear members
And is it really important to have ZDDP ?......YES
I'm taking cover now lol......PS ask a moderator to remove this tread....& yes take cover
MJ in Beirut
Either Dino or Synth 20w50 will be just fine as long as it's a quality oil.
83-944 show room -sold___New ride 93-968 with SC steering wheel-ROW signal ligths- Susp M030 mods lowered,Porsche VA springs- Adjustable struts - Bilstein inserts - Bilstein sport rear -LSD -riding on Cup 1 wheels 17x8 frt 17x9.5 rear road contact Falken 452/ 225-45 ZR Front 255-40 ZR Rear -- Motor Mods /chip /K&N / mod air boxe just love the handling & power
Old 12-31-2014, 10:26 AM
Cheers
Phil
Sure, I did already. That's why i wanted the feedback of members on the forum as there seems to be 2 schools - one is mineral GTX (with no zddp) or Mobil 1 fully synth. But no one seems to have a clear singular view.
I can't help feeling that Mobil 1 fully synth would do the engine some favours
MJ
Old 12-31-2014, 12:14 PM
333pg333's Avatar
What is 'idepaal' ?
ZDDP whether turbo or n/a....
Patrick
Youtube 333pg333
86 modified 951
Old 12-31-2014, 01:12 PM
FLYGEEZER's Avatar
This thread could go on forever......But don't put synthetic into an engine that has lotsa miles running dino oil. Promise ya...your gonna do nothing but "make it leak" from everywhere! My nonturbo has 144,000 miles, has had nothing but Shell Rotella 20W40 (dino) year round in Kentucky heat/cold for it's entire life. Never been apart, (belts,water pumps & pullys Sure!) Great oil pressure, never a whimper & DRY. But thats my opinion ....based on my experience.
Edgar
1984 Porsche 944 bone stock
1995 Mercedes E320 wagon
1970 Honda CB350 mint!!!
Old 12-31-2014, 01:48 PM
Originally Posted by 333pg333 View Post
What is 'idepaal' ?
sorry, that was a typo due to a very old laptop which will soon be chucked off the balcony once i replace it.
"Ideal oil" it was meant to read.
So, you're saying that a zddp oil is only relevant for a turbo?
MJ
Old 12-31-2014, 11:34 PM
MJ
Hi, I think he wanted to say that higher zddp levels than the ones that you find in "ordinary'' modern oils would be recommended both for turbo and naturally aspirated engines.
Old 01-01-2015, 03:23 AM
Northern Motorhead
wildcat077's Avatar
MJ,
To make it simple ... i use Mobil 1 15W50 synthetic in both my 89 911 with a 3.6 transplant as well as my 944 SP2 race car ...
Been using it for the past 6 years on my 911 and no it didn't cause my engine to leak everywhere as i personally think that's a myth.
The ZZDP is more critical on flat tappett engines like the 3.2 !
Cheers
Phil
Cheers
Phil
Old 01-01-2015, 07:11 AM
MJ,
Cheers
Phil
thanks Phil. Appreciate that. But if that is the case (zddp), why go to the Mobil 15/50 when GTX 20/50 dino would be perfectly adequate. Just curious. And thanks for your patience on a subject which tends to rattle people quite a bit.
MJ
Old 01-02-2015, 08:31 AM
For a hot area like you are in, you want a thick oil like a 20W50 non synthetic oil, using synthetic could, and probably will cause the seals to leak because synthetic is so much smaller molecules than dino oil, that it will find areas to slip through. I use Valvoline VR-1 racing 20W50 oil in my 85.5 Porsche 944 because it has more ZPPD than most other oils.
Old 01-02-2015, 09:57 AM
333pg333's Avatar
Yes, I meant in both n/a and turbo. In turbo it's probably more important due to extra heat in the system but really, it doesn't matter. Both motors should run an oil that has the appropriate ZDDP package. You can also have too much of it by the way, but there aren't very many oils available with that content.
Patrick
Youtube 333pg333
86 modified 951
Old 01-08-2015, 01:59 PM
