8 volts at sending unit? HELP
Recently replaced the clock from my 85-1 944 with a VDO oil temperature gauge. I tapped the keyed power source for the radio. The gauge produces very low readings - oil temps of just 130*F. This can't be right, so I measured the voltage going to the sending unit and have only 8 volts there. How is this possible? What am I doing wrong? THANKS GUYS!
Old 01-22-2015, 02:52 PM
944 addict
mytrplseven's Avatar
Send a message via AIM to mytrplseven
Low volts
Are you tapped into the voltage line for the lighting for the radio and the clock? It could be the line from the light dimming circuitry. Move the dimmer thumbwheel to full bright and see if that fixes it.
3 944's, 2 Boxsters and one Caman S, and now one 951 turbo. Really miss the Cayman.
Some people try to turn back their "odometers." Not me. I want people to know 'why' I look this way. I've traveled a long way and some of the roads weren't paved.
Old 01-22-2015, 03:25 PM
Thanks man! I will check.
Old 01-23-2015, 04:29 AM
