Garage Helper
Cocacolakidd's Avatar
Send a message via Yahoo to Cocacolakidd
Speed and reference sensors
Hello gang,
I ran into a quirky problem when working on my 85.5 944 - On the mount block that mounts the speed and reference sensors is a third sensor to the outside of the other two - I can find no reference to this third sensor in the manual or any place else.
Pfunny time to run into something unknown as I have the mount block and other sensors pulled out - even have a washer filed down to .8mm and glued to old sensor for clearance purposes when re-mounting.
What is this third sensor - what is it for - are their any clearance or mounting instructions for it?????
TYVM in advance, Ed.
(Thank you very much)
78-924 traded for 80-931 traded for 84-944 traded for 85.5-944 (7th one now).
UAV-M1 (Urban Assault Vehicle - Model 1)
Bless the lowered, and pass the nitromethane.
Pedal to the metal till you see the gates of hell then brake
NLA - No longer available is a four letter word
Old 01-22-2015, 09:48 PM
Hi Ed, the third large opening is for a factory diagnostic plug which is no longer used.
Cheers,
Larry
Retired USAF and Civil Service,
1985.5 NA Graphite Metallic, A never ending work in progress,
1992 968 Horizon Blue Cab "New Toy"
Old 01-22-2015, 10:20 PM
Garage Helper
Larry thanks so much - Couldn't hardly feel good about putting it back together with out knowing what that third sensor was for...
tyvm, Ed.
Old 01-22-2015, 11:57 PM
