944 5-speed trans. problem
Which shaft is the 2nd gear synch. ring on. Or what number is it on the drawing. 2nd and 4th are the same and I want to be sure I replace the correct one. Thanks
Old 10-26-2002, 06:16 AM
SoCal Driver's Avatar
Do I take it you have a trans apart?
What drawing with numbers are you refering to?
Hugh - So Cal 83 944 Driver Person
NOT a 'real' Porsche -- Its Better!!!!
When was the last time you changed your timing and balance belts and/or cam chain and tensioner?
New Users please add your car's year and model to your signature line!
Never break more than you fix!
Old 10-26-2002, 09:10 AM
I have the transmission apart. There are parts diagrams on the Pelican Parts Page. The parts diagram is on the left side after I click Pelican Parts and under 924/944/968 is a line for parts diagram.
Old 10-27-2002, 06:50 AM
OK. Back home from weekend retreat.
I'll scan and send both a diagram and the related parts referances.
Old 10-27-2002, 09:17 PM
