				Altitude sensor
			I have a 1985.5 944 non-turbo. Would the altitude sensor cause the car to just die abruptly? The car will run and drive for about 5 minutes and then it dies. But, it starts right back up and runs and drives for another several minutes and then dies again, so on and so on. I have replaced the speed and crank sensors, rotor, dist. cap, DME relay and spark plugs and cleaned all the battery connections and grounds. I am getting ready to throw some more parts at it such as a new ignition switch, coil and spark plug wires. I have also done the wire jumper fix (per Clarks garage) on the alarm. I was just wondering how important the Altitude Sensor Box is because it sounds like something is loose inside of it but I really did not want to spend 60 bucks on a new one if there is no way it can cause the intermittent problem I am having. If there is a possibility that it is causing the problem I will go ahead and replace it. I live in San Antonio, TX where the altitude is 700 ft above sea level. If a new coil, wires and ignition switch does not fix it, I am afraid the DME computer is probably the problem. Thanks
