RedDragon87P944 (guest)
Guest
Posts: n/a
1987 Porsche 944 Base. Factory alarm is constantly pulling 11-15 volts clearly draining my battery, I have tried disconnecting, turning the alarm key on/off, and bypassing and still cannot shut off the voltage. The warning buzzer relay is missing but the alarm can still go off? Help!
This post was auto-generated based upon a question asked on our tech article page here:
Old 05-28-2015, 10:05 AM
Do you mean 11-15 amps?? I don't think an alarm could pull that many amps. How are you testing the draw? Are you sure there is not another aftermarket alarm installed?
- Casey
