What to replace on Transmission
I have a 1983 944 that me and my dad are having SOooooo.... much fun restoring. I just found out that I have replace the oil pan gasket. Anyway, so we purchased this car and we found out that there's rust in the gas tank. We removed the transmission and I'm wondering, since it's out, are there any gaskets that I could replace just because? It was super dirty but then again, the car sat for awhile in who knows where. Thanks for any advice you might have.
-Derek
Old 06-12-2015, 03:12 PM
Dimi 944's Avatar
There are not my things that could be replaced without disassembling it. You can replace the output flanges seals and the selector rod seal but you will have to extract the it out.
Dimi Paralanov
Flying Horse Motorsport
flyinghorsemotorsport@gmail.com
Old 06-13-2015, 06:08 AM
Volhv's Avatar
If you do the output shaft seals definitely do the input also. You could even skit the outputs, since they can be easily done with the tranny installed.
My input shaft seal is just started leaking pretty good...... looks like I'll have to pull the transmission out again....
1986 944 NA Sapphire Metallic
http://944porsche.blogspot.ca/
Old 06-13-2015, 11:38 AM
ASE Master
alfadoc's Avatar
I would recommend this very inexpensive upgrade while it's out:
Shift Linkage Arm - Only944.com Awesome new Porsche 944 parts
1989 944S2 (sold after 11 great years)
1980 911SC Weissach (bucket list car)
1975 914 1.8 (future restoration)
1993 968 Coupe 6 speed (new acquisition)
Old 06-13-2015, 12:21 PM
Patrick
pfarah's Avatar
Also, while the tranny is out, you may want to rebuild the torque tube as those bearings are quite old.
1984 944 NA, constant tinkering
1983 "Beastie" - Safari Build
Old 06-13-2015, 05:46 PM
kevingross's Avatar
Output flange seals, input shaft seal, and give the transmission a decent cleaning with something like a citrus degreaser.
Kevin
Catellus Engineering
catelluseng@gmail.com
http://www.catellusengineering.com
https://www.facebook.com/catelluseng/
Old 06-13-2015, 07:07 PM
Proprietoristicly Refined
John_AZ's Avatar
Rust in tank.
Replace the fuel tank strainer and sea.
1987 Porsche 924 S Coupe - Fuel System - Page 3
Replace the hose to the fuel pump.
Clean the fuel pump check valve.
Replace the fuel filter.
If fuel hoses cracked-replace.
Then go to the engine bay and check fuel lines.
Replace the FPR & FPD
Remove the injectors and send out for cleaning and reseal.
...a good start.
J_AZ
1988 924S, 85,750K ..+ 1987 924S, 154K DD (+15K est. bad odo)
Old 06-14-2015, 06:09 AM
