rbt944's Avatar
Electrical Problem??
Okay a little history, I've had my car for a year now. Ever since I got it the CASIS never worked and the MPG gauge always stays to the right by 60. It never moves from there when I turn on the car. Also, in the ignition, if I just press where the key goes the accessories turn on. Whic is kind of weird.
Just now when I was coming home, I turned on my car and the MPG gauge and the CASIS was working. Then in less than a minute it all went back to normal. Can anybody tell me what wires to check out that could be causing this? Maybe a bad ground somewhere? I need help.
-Gus.
-Gus
2000 kawasaki zx6r
1984__944.
pictures
Old 11-06-2002, 06:20 PM
AFJuvat's Avatar
definately a bad ground somewhere - check ehind the intstument cluster - check all wiring connections and the like
AFJuvat
Es geht nicht darum wie schnell man faehrt, sondern wie gut man schnell fahren kann.
Ihr Brunnen der nutzlosen Porsche Information
Old 11-07-2002, 03:29 AM
rbt944's Avatar
Thanks. I'll get to it tommorrow when I have no school.
-Gus.
-Gus
2000 kawasaki zx6r
1984__944.
pictures
Old 11-07-2002, 09:36 AM
SoCal Driver's Avatar
What year and model of car?
Please add this to your siginture line as this does determine the answer to your questions.
I can guess by your handle that it's a 944.
As to what you currently report; replace the ignition switch.
Hugh - So Cal 83 944 Driver Person
NOT a 'real' Porsche -- Its Better!!!!
When was the last time you changed your timing and balance belts and/or cam chain and tensioner?
New Users please add your car's year and model to your signature line!
Never break more than you fix!
Old 11-07-2002, 12:21 PM
rbt944's Avatar
Sorry about that. It's a 1984. As to the ignition switch. I was wondering about that yesterday. Like I said, I would press on it and the accessories would turn on. All day yesterday I was pressing on it so the accessories would turn on, then when I started the car, the mpg gauge would work, but only for a couple of seconds.
Thanks.
-Gus.
-Gus
2000 kawasaki zx6r
1984__944.
pictures
Old 11-08-2002, 03:48 PM
Thanks.
-Gus.
Where in California are you?
Old 11-08-2002, 03:50 PM
rbt944's Avatar
In 'Rainy' Covina California. Enjoying the rain just 20 minutes from pasadena and 30 from L.A. (depending on Traffic).
Where is Costa Mesa close to??
Gus.
-Gus
2000 kawasaki zx6r
1984__944.
pictures
Old 11-08-2002, 03:58 PM
Gus.
Down the coast from you; Orange County. Next to Newport Beach.
Old 11-08-2002, 04:35 PM
rbt944's Avatar
Cool. We should have a S. California 944 BBQ one of these days. Anybody up for that????
-Gus.
-Gus
2000 kawasaki zx6r
1984__944.
pictures
Old 11-09-2002, 01:40 PM
todwic's Avatar
Send a message via AIM to todwic Send a message via Yahoo to todwic
Yo! I'm down with a BBQ~! Lakewood here, just norte of you O.C.'ers.
*Disclaimer: The person above is actually dumber than he appears.
my web site Torque values maintainance and repairs lots of my rebuild pics weights and measurements
'84 944 auto/ps/ac/cc
'86 951
Providing ignorance one post at a time.
Old 11-09-2002, 11:25 PM
rbt944's Avatar
Allright. When the weather clears up and I finish drying the inside of my 944 I'm all go. Anybody else??
-Gus.
-Gus
2000 kawasaki zx6r
1984__944.
pictures
Old 11-10-2002, 05:13 PM
What got wet in the car?
Old 11-10-2002, 05:14 PM
rbt944's Avatar
All of the carpet on the drivers side. After coming back from school on Thursday. I parked my car and didn't drive it until yesterday. When I opened the door, I notice the back floor right behind the drivers was all wet. Completely soaked. I hop in, and heard a drop of water as it hit my foot. I knew exactly what it was. When I bought the car, it had an alarm. They drilled a hole through the firewall, right where all the water accumulates from the windshield, opposite the battery. The alarm was giving me trouble so I removed it. Leaving the hole right open.
Also, back to electrical problems. The buttons on my passenger's door don't work. It can only roll up the windown and not down. And with my buttons, I can roll it down and not up. I also found two wires under the glove box that were cut. Don't know where they are from .
-Gus.
-Gus
2000 kawasaki zx6r
1984__944.
pictures
Old 11-10-2002, 05:36 PM
You need to clean the switches for the windows.
The passenger side window gets it's current from the drivers side passenger window switch. Clean this one first.
Not that difficult to clean. A bit of a challenge to reassemble the first couple of times but doable.
Trick is the direction of the spring contacts on the two internal points rockers.
If you are up to it I can scan in some of the pieces and draw a diagram or two.
I always have a spare window switch in the car right next to the spare DME relay.
Old 11-10-2002, 06:15 PM
rbt944's Avatar
I had cleaned them before. And they were working good for a while. I think I'm going to clean them again tommorrow before I go to work.
Sure, that would be helpful.
Thanks!
-Gus.
-Gus
2000 kawasaki zx6r
1984__944.
pictures
Old 11-10-2002, 10:48 PM
