-   -   Procedure to replace fuel injectors in an S2? (http://forums.pelicanparts.com/porsche-924-944-968-technical-forum/874894-procedure-replace-fuel-injectors-s2.html)
smlporsche 07-15-2015 11:57 AM
Does anyone have a write up ( preferably with pictures :):) ) on how to replace the injectors?
I have to replace the one closest to the firewall...
Thanks!
Bradical 07-15-2015 12:03 PM
Its easier than you think. Unbolt the fuel rail from the intake and gently wiggle the rail until they walk out of the intake. Stick some towels in the intake to prevent anything from moving in. The injectors are held onto the rail by square clips that pop off easy with a small flathead. Then they pull right off the rail. Some gas will dribble out too, be prepared for that.
The seal kit from pelican comes with the o-rings and plastic bushings you need. Everything literally pops on and off by hand. All you will need is a small screw driver and a pick for the O rings.
When you go to put them back, the new plastic caps for the end hold the O rings in place. Lube the rings and push them in using the rail back into the intake. Its a 1/10 on the difficulty scale for sure.
400th post!
Bradical 07-15-2015 12:05 PM
I implyed that if you are replacing one it would be smart to go ahead and get the rebuild kit and replace the O rings and bushings on the other three. It would be a pointless excersize in my opinion to try to just remove one single injector.
944tothefloor 07-15-2015 01:05 PM
Bradical makes a good point. I think it's best to have the injectors flow-matched, meaning they all produce equal pressure/spray
Bradical 07-15-2015 02:48 PM
That too! Thats not too terribly expensive to have done, either.
vette951s 07-15-2015 04:59 PM
Just a heads up - the injectors for a '89 - '90 S2 are different from a '91 S2 and most vendors list only one injector for all S2s. You can read more at my for sale post here: http://forums.pelicanparts.com/porsche-924-944-968-used-parts-sale-wanted/742912-fuel-injectors-944s2-tech-info.html
John
sjv 07-15-2015 07:59 PM
91 s2
I am intrested in 91 injectors 781-249-4944
thomasryan 07-15-2015 08:54 PM
Thoroughly clean where the injectors push into the manifold. You don't want dirt in the holes.
Kill your fuel pressure by letting it sit overnight or any other method and disconnect your battery. Have an extinguisher handy just in case.
As noted above and try not to twist the injectors when inserting them and make sure they are seated completely when installing the rail. (Don't use the rail mounts to push the rail down)
smlporsche 07-16-2015 06:23 AM
Thanks Guys!
As an fyi I did have the injectors removed and cleaned by Witchhunter but when my "mechanic" went to install them he botched the one closest to the firewall. I found out on the first out lap at the track!!!
Anyway there was a real mechanic at the track who was able to diagnose the problem but didn't have a spare injector there so I ordered a new one and hope to do the install myself.
Thanks again...
