Self-Proclaimed Newb
Trans Coupler Threads Stripped
Well, I learned a valuable lesson; always get both transmission coupler bolts started before doing final tightening on either of them. I tightened down the front bolt before turning the engine over to do the rear, and it must have been far enough off that I sheared the threads off on the rear bolt against the sides of the groove. Can't really think of another explanation.
![]() What are the chances the threads in the coupler are still good? I *really* don't want to have to drop the trans again. I'm a slow worker. Any way I can test them without risking getting a new bolt stuck?
Current: 1986 944 Turbo - Sapphire Past: 1983 944NA - Black (RIP) 1985.5 944NA - Guards Red (in purgatory) 1985.0 944NA - Maraschino Red (traded for a Volvo 244 ![]() Last edited by Brozoar; 09-17-2018 at 09:09 AM.. |
In the Fires of Hell.....
Threads will be fine. Get a new bolt and get them both started before tightening, like you mentioned.
PCA Instructor: '88 951S - with LBE, Guru chips, 3Bar FPR, 1.3mm shimmed WG, 3120 lbs, 256 RWHP, 15 psig boost |
West Central Ohio 45380
Yep done this a few times. Coupler is fine
www.plyhammersparts.com |
It's good to hear I'm not the only one to commit this gaffe. Thanks, guys!
Current: 1986 944 Turbo - Sapphire Past: 1983 944NA - Black (RIP) 1985.5 944NA - Guards Red (in purgatory) 1985.0 944NA - Maraschino Red (traded for a Volvo 244 ![]() |
Yeah, get the alignment perfect before doing rear bolt.
With the front bolt tightened, you can actually pry on square block to shift driveshaft fore-aft so hole of 2nd bolt is perfectly clear. I use a motorcycle tyre lever. |
Also put that coupler in a vice or something else to secure and clean the threads with tap.
Patrick
I believe the manual recommends to replace these bolts as they one-time use (micro-encapsulated).
1984 944 NA, constant tinkering 1983 "Beastie" - Safari Build |
