No Spark Help
Have a 84 with 180 compression in all cylinders, have 12v to coil, not getting any spark to the plugs.
How do you check wires , it has fuel also.
Tried new cool but results are the same.
Car ran and sat for a year then this problem arose.
Any ideas would be great.
1981 930 Euro 56K
2002 996 TT
1984 944 32K
1990 944S2 Cab 75K
1977 924 Martini & Rossi 52K
Old 09-27-2015, 10:17 AM
Bradical's Avatar
I am guessing if you have 3 water-coolers you've probably seen this website before. Clark's Garage Home Page
PCA - Florida Citrus Region
Old 09-27-2015, 10:35 AM
did you do the wires, cap and rotor? ive burned through 2 rotors in 3 years and it runs better every time i change it.
hope you figure it out
Old 11-01-2015, 04:28 AM
Yeah this is 944 basic basics. Clark's Garage, DME relay, coil signal, tach bounce, loose distributor rotor, etc. You can ohm your spark plug leads but it is not likely they all failed at the same time.
12v to coil is good but the ground pulse is what sparks it.
1987 928S4
1992 968 cabrio
2009 957 Cayenne GTS
Old 11-01-2015, 06:04 AM
Actually traced back to the DME, replaced it, started right up.
1981 930 Euro 56K
2002 996 TT
1984 944 32K
1990 944S2 Cab 75K
Old 11-01-2015, 06:37 AM
