Sehrgut's Avatar
Arrow O2 sensor wiring - I seek the Truth...
'84 944 NA 1 wire O2 sensor wiring. The orange connector at the firewall for the O2 sensor has disintegrated, along with the reference sensor plug connectors. Question is, can I simply splice in a piece of new wire and use spade connectors on the O2 wiring without any ill effects? Also, does anyone have two good male end reference sensor connectors/wiring they are willing to part with? Electro tape looks really crappy. Thanks for all your help! Please keep in touch - it's getting cold here in Misery (Missouri - LOL).
1984 Porsche 944 NA
Old 10-11-2015, 04:12 AM
Yes you can just splice in new connectors no problem. Someone will probably come along saying you should solder the connection.
If you go to an auto electric supply shop you can find "quick connect" insulated pin connectors like a trailer light plug with only 2 pins, that's what I have on mine.
Old 10-11-2015, 06:49 AM
Sehrgut's Avatar
Thanks V2Rocket!
Thanks v2. Since I couldn't unplug the O2 connector without further destruction, I just electro taped that lil' bugger and put it back in the bracket. Thanks for your input. I really appreciate it! Now onto those darn reference sensor connectors. I just hope I have enough tape. Gotta get me some of those connectors.
1984 Porsche 944 NA
Old 10-11-2015, 09:10 AM
Proprietoristicly Refined
John_AZ's Avatar
RocketMan is correct-just splice-also per Clarks:
Oxygen Sensor General Information, Testing, and Replacement
Or--
Yes, this is called the galvanic effect and is the basis of how
thermocouples are made. Dissimilar metals have a contact potential that
varies with temperature. If the solder is between the two wires, any small
temperature difference will create a voltage across the joint, hence giving
a bad reading. You got good advice. (Dave Harrison-guest)
dr. J-AZ
1988 924S, 85,750K ..+ 1987 924S, 154K DD (+15K est. bad odo)
Old 10-11-2015, 11:02 AM
plays with toy cars
sausagehacker's Avatar
On mine there was a 1-pin GM weatherpack connector, no problem.
Old 10-11-2015, 07:39 PM
You can get replacement speed/ref sensor connectors for both sides from Mouser. Part# listing here: DIY harness connectors
Old 10-14-2015, 12:33 PM
