944 addict
How do you get the sensor bracket loose?
Is there a secret to loosening the speed sensor bracket allen screws? Is it possible to do this without removing the heater control valve? I've tried every angle and tool combination in my box to try to get access and It's starting to look like the heater control valve needs to come out. I hope not.
Any one out there that's overcome this. please chime in. Thanks
3 944's, 2 Boxsters and one Caman S, and now one 951 turbo. Really miss the Cayman. Some people try to turn back their "odometers." Not me. I want people to know 'why' I look this way. I've traveled a long way and some of the roads weren't paved. |
I bought a foot of heater hose and relocated my heater control valve back and towards the passenger side- I recommend that mod because it not only moves it out of the way of the sensors, but if it ever fails it wont leak coolant into the inspection hole. With the engine cold I lost very little coolant in the process.
If the sensor bracket is stuck, dont forget to remove the third sensor towards the drivers side- the little diagnostic sensor that is NLA and not needed will keep the bracket from coming out
PCA - Florida Citrus Region |
944 addict
Well, today I pulled off the upper hose of the HCV and moved it out of the way. I plugged up all the miscellaneous holes so nothing would get on the clutch. Guess what? Some idiot in the past (probably the one who left off the shim) used a TORX head bolt instead of an allen head. No wonder I couldn't get the thing to come off. Tomorrow I'll hook up the connectors and see how it goes. Once the bracket was loosened, the shim on the end of the sensor probe method couldn't be easier.
Bob Cox 78 930 clone project car. 87 924S resurrect at some point. 84 928S, Ruby Red linen/brown interior - sold ![]() 86 944 turbo my new DE/track car - sold
