Send a message via Skype™ to massive
Maintaining revs after cold start
Currently have an inconvenient issue where the revs will drop and stall the car after a cold start.
The car starts first time no problem in the morning and the revs idle around 700-800 rpm quite happily, I then reverse off the drive and go to put it in 1st but the revs will drop before I have a chance to move away and the car stalls. I then start the car again and drive away and the problem goes away until I do a cold start in the evening or the next day.
1984 944, 2.5L, manual transmission, UK right hand drive.
http://944foot2thefloor.blogspot.com/
Old 11-12-2015, 09:05 AM
Toofah King Bad
Rasta Monsta's Avatar
There is a component in the fuel injection system designed to prevent this problem, the ICV or idle control valve. A few things can cause ICV problems.
1. ICV missing, unplugged, or non-functional.
2. Idle air bypass screw out of adjustment.
You can consult Clark's Garage for idle adjustment procedure.
If all that checks out, I would next suspect the coolant temperature sensor.
» 1987 924S Turbo - Got Boost? «
"DETERMINATION. Sometimes cars test us to make sure we're worthy. Fix it." - alfadoc
Old 11-12-2015, 12:36 PM
Volhv's Avatar
I got the exact same thing happening.
Definitely the ICV. Did not want to open or close when applying voltage to it, until I cycled it a few times. It was slow to operate..... I need a new one.
Adjusted the idle via the screw when I resealed the throttle body last weekend. Now it idles great when it's warm.
The ICV sometimes decides to start working again but usually I need to keep the throttle depressed so it won't stall out while idling till it warms up.
1986 944 NA Sapphire Metallic
http://944porsche.blogspot.ca/
Old 11-12-2015, 07:22 PM
Early 944 doesn't have an ICV, it has an Auxilary Air Regulator and an Electric air Valve
Guess I should check my own blog posts more often944 Foot To The Floor: Erratic Idle Problem Porsche 944 (Square Dash Model)
Old 11-13-2015, 07:46 AM
Tags
cold start , revs
