loud metallic clunking noise from front on breaking
Dear All
i hit a mother of all potholes in Beirut on the left wheel, which resulted now with a loud, worrying sound. The sound comes on when breaking and when the car goes along a bumpy road but not when driving continuously or accelerating, or turning for that matter. Please point me out to the obvious culprit. A mechanic looked at it today and was honest enough to say he couldn't find the problem but identified that there was a fair amount of play in the passenger side steering joint. I don't think this would make this loud metal-on-metal sound though. It almost sounds as though the entire suspension is creaking and giving way many thanks MJ in Beirut |
Proprietoristicly Refined
Front struts.
J_AZ
1988 924S, 85,750K ..+ 1987 924S, 154K DD (+15K est. bad odo) |
Yeah.. Sounds like you may have popped a strut.. A violent impact can pop a seal or even bend the rod inside causing it to rub inside.
+1^
Replaced a set a few years ago that had a "clunking", metallic, sound. I bought the Sachs inserts-work well and long lasting. J_AZ
But can the rod inside be lubricated so it does not rub? Or rebent back? |
Nope... Gonna need a new one. Unless it's a Koni or Bilstein that can be rebuilt, it's probably a sealed Sach's unit. It'd be much easier and cheaper just to replace it.
It could be a broken strut mount or broken sway bar end link or missing A arm bushing. One might assume the wrench could spot this, but you never know.
It's also a good idea to check the caliper mounting bolts. -Joel.
1987 928S4 1992 968 cabrio 2009 957 Cayenne GTS |
944 addict
I had one that was binding. Sounded like a loose wheel whenever the front suspension moved. I found it by pushing down on the front corners of the car and watching for rebound. The bad strut refused to allow me to push down on that corner. Replace both struts at same time so you get a balanced rebound.
3 944's, 2 Boxsters and one Caman S, and now one 951 turbo. Really miss the Cayman. Some people try to turn back their "odometers." Not me. I want people to know 'why' I look this way. I've traveled a long way and some of the roads weren't paved. |
My two cents are on a bad control arm bushing.
You really need to add your car to the signature btw.
dolor et pavor Copyright |
