'87 924S
Also keep in mind that a four stroke engine has two TDC per cylinder, hence the suggestion mentioned early on in this thread to take the dist cap off so you can figure out if you are at TDC exhaust stroke (i.e. exhaust valve closing, intake valve opening) or TDC compression stroke (i.e. intake valve closing, spark about to fire).
It's good practice to keep in mind which TDC you are trying to reference. What I do to find TDC compression stroke is take the spark plug out of #1, put a piece of tissue in the spark plug hole (enough that it doesn't fall in of course!) and when the tissue blows out while rotating the motor, you know you're on the compression stroke. Then a screw driver or fancy dial feeler gauge will get you to TDC. If you're looking for TDC exhaust stroke, then of course you go round one more time. Then you can verify that your cam belt and distributor rotor are on correctly. Maybe it's overthinking it a bit on a SOHC engine...I'm used to working on quad cam V-6's Last edited by trinitrona; 03-17-2016 at 01:44 PM.. Reason: typo |
@sausagehacker : I'll have to understand those bolts first before I drizzle. |
I'm confused by that post. lol Simple rule, cam goes twice as fast as the crank.
dolor et pavor Copyright |
'87 924S
@ Bukowski: You're correct of course, the pin is slotted, so the rotor only goes on one way. Apologies for the confusion. Again, I'm more familiar with engines where the distributor is geared off the cam, or for added fun, off an auxiliary shaft. In that type of arrangement, knowing which TDC you are at in the engine stroke is important because it is very easy to install the distributor 180 degrees wrong. Anyhow, let's just say working on a 944 8V NA motor has been pleasant compared to a Maserati V-6 with about 6 feet of timing chain: http://tinyurl.com/hbk5ju7
He is saying that if you use the mark on the flywheel you may be on the exhaust stroke with the cam 180* out. You will then need to rotate the crank another 360* to get the engine to TDC.
1986 944 -Garnett w/Koni suspension 1987 924S -Red, 951 Swapped, ~300hp 1987 924S -Red, project car 1987 924S -White, Project car 1988 924S- Red, Bone stock, Daily driver |
plays with toy cars
there are 6 plugs, 8mm allen head. Go slow and be careful, they strip. Happened to me twice now. now, just pour some oil in each hole (they're just access holes, the inner cavity only contains the cam and its journals/bracing). You want to have some oil present on the cam lobes and lifter faces as you turn it, ideally.
1983 944 - modded everything http://forums.pelicanparts.com/dto_garage.php?do=viewvehicle&vehicle_id=28317 '86 951 - under construction http://forums.pelicanparts.com/dto_garage.php?do=viewvehicle&vehicle_id=28374 |
