Try my no-start question : quiz style
i dont know if there's an answer, but sounds like it. fill in the blank below. Yes this is all about my no-start:
You put new spark plugs in your no-start late NA 944 that gets a steady ~2.5 bar of fuel pressure. Turn the key, get spark from all plugs, starter goes, but another no-start. Try a few times. You look at the spark plug tips : one is blackened, the others like new. This means _________(no word limit)_____.
... My guess is three failed injectors and one good one in a cylinder with oil leaking, but I think that's wishful - it's probably more than that.
Old 02-19-2016, 01:14 PM
I will play by the rules:
This means since I cannot detect fuel in the three clean plugs_the shop messed up the injector seals job. Maybe they didn't connect the harness properly, or possibly wires broke in the harness_____.
Old 02-19-2016, 04:13 PM
This means it is time to pony up for a set of noid lights... They will tell you if the injector is getting a pulse from the ECU....
Good luck, George Beuselinck
Old 02-20-2016, 05:11 AM
OK, noid light - there's all these acronyms out there like "Bosch PFI" - so what is the late NA 944 Bosch L-Jetronic / Motronic? EV1 like I found/said the other day?
... and about noid lights - can't I just put a 12 volt LED in there?
87 944 NA
Old 02-20-2016, 06:45 AM
It is a little more complicated than using a simple test light since the electrical pulse is too short to see without a NOID light (some magic I don"t fully undersatnd). However it only checks the ECM and not the injector.
https://www.youtube.com/watch?v=5MmR-wXddVw
To test the injector you would need to check the resistance of it or test fire it by tapping a test lead against the battery terminal.
https://www.youtube.com/watch?v=hZrRVWe2Km4
For your situation you might want to start with the 2nd video if you already have a dvm.
Old 02-20-2016, 10:24 AM
Arizona_928's Avatar
Vielleicht. buy a set of noid lights. They're ev1 style used on everything. Sounds like you are not getting pulse. go over the basics. tach bounce, speed reference. Confirm spark. ect ect
dolor et pavor
Copyright
Old 02-20-2016, 09:46 PM
