Composite Shop Owner, DJ
MixMasterK's Avatar
Send a message via MSN to MixMasterK Send a message via Yahoo to MixMasterK
O2 sensor question
Thinking about installing an A pillar gauge set with A/F and vacuum gauges. If I switch to the wideband O2 sensor, which sounds like people are having to do, is there any adverse or positive effect to the engine?
Also, what is the part number for the WB sensor?
What gauges seem to work best, most accurate, etc.?
'86 944, 5 Speed (Daily Driver)
Old 03-17-2016, 11:47 AM
For a non turbo 944, a wide band 02 sensor is a cash flow device, from your pocket to the seller's pocket.
For a turbo, install an extra bung in the cat pipe and plumb in a wideband sensor, but you will need additional hardware to tune the software.
Good luck, George Beuselinck
Old 03-17-2016, 12:22 PM
Unless you have tuning capability, don't bother with a WBO2.
If you do, I ran an AEM gauge for a while that worked as intended.
Old 03-17-2016, 01:48 PM
That Guy
Techno Duck's Avatar
Good advice from the above. It is possible to install a wide band that outputs a narrow band O2 signal for the DME to interpret, this lets you avoid having to weld another bung in the exhaust. Most of the wide band controllers have this feature nowadays. The other option is to weld in another O2 sensor bung somewhere before the cat.
I wouldnt bother doing this on a n/a though. It is handy for setting idle mixture if you think yours is out of whack, but its a literal one time use tool... i would try and borrow one from someone in that case.
AEM and Innovate are the only two brands i would consider.
Jon
1988 Granite Green 911 3.4L
2005 Arctic Silver 996 GT3
Old 03-17-2016, 04:48 PM
944 addict
mytrplseven's Avatar
Send a message via AIM to mytrplseven
For my 951 I chose the Innovate system and it helped me diagnose the engine issues I was having. It's mounted on the A pillar with the boost gauge. For an N/A you won't need this devise because the engine isn't as vulnerable to mixture issues as the turbo. It has it's own software and a plug to tie in to software for monitoring the health of the car.
3 944's, 2 Boxsters and one Caman S, and now one 951 turbo. Really miss the Cayman.
Some people try to turn back their "odometers." Not me. I want people to know 'why' I look this way. I've traveled a long way and some of the roads weren't paved.
Old 03-17-2016, 05:02 PM
Kessel run in 12 parsecs!
Fast Freddy 944's Avatar
Thumbs up
You know, the Porsche 928 has a unique O2 sensor warning system, under the passenger seat they have a box that emits a clicking noise when its time to replace the sensor, the 944 I'm unsure of?
Old 03-19-2016, 06:42 AM
The 944 has no such mechanism.
That said, you can test the oxygen sensor using a VOM and a propane torch. You couild google the various youtube videos on how to do that.
Old 03-19-2016, 06:47 AM
Thumbs up
Thanx bro, I am now lernid!
Old 03-19-2016, 07:01 AM
